Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
  #16   Spotlight this post!
Unread 03-04-2016, 16:20
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Re: Colson Performa Safety
Originally Posted by jnicho15 View Post
Have any teams that use Colson Performas on their shooter mechanism experienced any issues with delamination or other high-speed failures? Our team is considering using the 4x2 hex bore wheels on our shooter at nearly 10,000rpm and are worried about safety issues.
Do not take these speeds lightly, we are running some drive rollers from McMaster at about 5000 rpm on our robot. We had some issues with the rubber delaminating on part of the hub and allowing it to expand one part of the wheel too much. This caused the wheel to unbalance to far and rub against things tearing parts of the wheel off slowly. We fixed this problem by banding the middles with safety wire and burying the twisted end into the rubber of the wheel.
The following video is an attempted destruction test of said banding method, the wheel in the video plateaus at 7,750 rpm and the surface of the wheel is seeing nearly 3,000 G's of outward force.
https://www.youtube.com/watch?v=vOYEp6tjQDg
11 Years and counting! Over a third of my life has been spent with FRC.
  #17   Spotlight this post!
Unread 03-04-2016, 19:17
Tim Lehmann4967's Avatar
Tim Lehmann4967 Tim Lehmann4967 is offline
A Sentient Being
FRC #4967 (That O.N.E Team (Our Next Engineers))
Tim Lehmann4967 will become famous soon enough
We are using two Colson Performa 4x2 wheels with press fit hex hubs on our shooter. They are driven by mini-cims and Versa Pro pulleys/belts and mounted with thunderhex bearings and 1/2in hex shaft. Max speed is 6,000 RPM and we haven't had any issues whatsoever.
L.A.S.E.R - Light Amplification by the Stimulated Emission of Radiation
  #18   Spotlight this post!
Unread 04-04-2016, 09:58
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Originally Posted by trumpthero786 View Post
I really like Colson wheels. How do you think 6 or 8 inch Colsons would hold up in Stronghold? I really wanted them early season, in the design period. Unfortunately VEX only sells up to 4 inchers which are good, but for obvious reasons aren't for this game. I wanted to get these ones or these but it ended up being easier to get traction wheels.
6" Colsons work great this year. 228 is running a 10WD on all Colsons with no problems. Colsons are particularly good when driving over a variety of surfaces, as they have good general traction on most any surface. That makes them a great fit for this game, really.
The only thing is you need to press fit hubs into them - Vex sells live and dead axle hubs (though check the OD on them before you press them in, they're sometimes too small / big). It's also not hard to make your own aluminum or delrin hubs if you have a lathe.
  #19   Spotlight this post!
Unread 04-04-2016, 19:21
C.Lesco's Avatar
C.Lesco C.Lesco is offline
Engineering Captain, Driver
FRC #5870 (League of Logic)
Team Role: Leadership
Rookie Year: 2014
C.Lesco will become famous soon enough
Pfft only 12 000? We have a PG71 running 1:1 via vex sprockets. 70rpm baby!!!! Had to remove since safety was worried the wheels would fly apart pulling the maximum fasts/hour
Rookie Allstar winner North Bay regional 2016 [Team 5870]
Driver 2015 [Team 4814]
Lead Driver 2016 [Team 5870]
Build, Design and Engineering Captain 2016 [Team 5870]
Mentor 2017 [Team 5870]
  #20   Spotlight this post!
Unread 04-04-2016, 20:00
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach - FRC Under Development
FRC #6370 (Texas Titans)
Rookie Year: 2010
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
Dual everything - 775pro --> 4:1 VersaPlanetary --> 1:1 VEX PRO gears transfer --> VEX PRO hex shaft --> 5"x2" Colson wheel/VEX PRO live hub --> 2.5" compression.
NOT a single problem.
But, I probably just jinxed us...
--Michael Blake
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- Head Coach / Founder - FRC 6370 Texas Titans < FRC and VEX teams under development - VRC 15842a >
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
