In 2015 there were these noodles spewed about all over the playing field. There was no foul driving over them but most avoided them as they could cause issues with their wheels. Although I disagree that unintentionally running over a boulder should be a foul I think after your find it they are calling it a foul it is your responsibility to avoid driving over them.
Re: Running over a boulder foul
Reading the rules, specifically the 2nd half of G38, it clearly states that running over a boulder inadvertently should not be called a foul. Unfortunately, the problem with this rule is that it is up to the referees to judge the intent of the driver. Anytime you ask a ref to judge intent, there are going to be issues. In cases like this, it is up to the FIRST to make sure that events are judged fairly and consistently. This is done by writing the rules well (and it seems like they tried to, with the use of examples to guide the refs), and by training Head Referees well.
I'm curious as well to see how this rule is judged at champs. Regardless of how it is judged by the Head Referees at champs, it is important that they be consistent across all 8 fields of play. Consistency of calls across regional events (as much as the inconsistency this year pains many of us) is much less important than the consistency of the calls made at Champs. FIRST must make sure that the head referees on each field, and on Einstein, are all making the same calls. G38 Examples of interaction with BOULDERS that are not “control” include, but are not limited to: A. “bulldozing” (inadvertent contact with BOULDERS while in the path of the ROBOT moving about the FIELD) |
Based on what I saw from the stands, the way the refs at the Hartford District called G38 seemed very fair. If a robot was in possession of a boulder and happened to drive over a second boulder, a ref would signal a five second count (similar to a pin count). After five seconds, if the robot was still in possession of two boulders, a foul was called. This kept the refs from having to judge "intent" while still allowing a case for a no-call on incidental violations. It also gave the drivers a clear signal that they were doing something wrong with time to correct it before the foul was called.
For G41, they called a foul any time a robot caused two boulders to move into their opponents' courtyard in a single crossing. Most of these looked like they could have been caused by the drivers simply not being able to see the second boulder. Usually it was between the robot and the defense being crossed, so they just bulldozed it through the outer works. Even so, I think this is a fair way to enforce this rule. Whether intentional or not, having one more boulder in your opponents' courtyard most certainly gives you an advantage. |
This was ruled a foul at both of our events (Kettering #2 and Howell). At least a few times, we had a boulder in our robot and accidentally drove over another one and a foul was called. I wish they wouldn't rule this as a foul as we aren't really "controlling" the boulder - we would drive off of the other boulder ASAP.
