Go to Post Spelling mistakes make me sad...Almost as sad as not being able to go to Atlanta this year.. Almost. - Elgin Clock [more]
Unread 02-04-2016, 12:11
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
Rookie Year: 2013
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
Building ntcore with mingw
So I haven't heard a response in this thread in a couple days now so I wanted to create a new thread.
My issue is that I can't build the ntcore library so I can use it on a Windows system using mingw + cmake. I keep on getting these errors whenever I try to build with
mingw32-make
I know I could try the visual studio compiler, but I need it to be built with mingw for 32 bit.
Another possibility is I could try to use UDP or TCP sockets. I much rather use network tables though.
Unread 02-04-2016, 21:41
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
Rookie Year: 2010
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
I'm currently on my phone, and your Google docs isn't opening. However, MinGW is not one of our supported platforms. We have precompiled versions available though. Look in either the c++ or java folders here http://first.wpi.edu/FRC/roborio/mav...networktables/. You want the - desktop classifiers for either the c++ or java. For c++, extract the binaries from the zip and grab the Windows one for your architecture. For Java, the provided jar will run on Mac, Windows, and Linux.
Unread 02-04-2016, 21:43
JohnM's Avatar
FRC #5854 (Glitch)
Rookie Year: 2013
Re: Building ntcore with mingw
Will try out. Sorry about it not opening. The reason is because it is a text file.
Unread 03-04-2016, 00:40
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Next time use gist or pastebin.
Also, I can't read it either on my desktop, it wants me to download a 0-byte file. :-/
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 03-04-2016, 22:00
JohnM's Avatar
FRC #5854 (Glitch)
Rookie Year: 2013
I decided to drop ntcore and just try to use a TCP socket. I want the robot to be the server and the ds to be the client. I'm using the winsock library on the Windows ds and my question was if this and this could be used for setting up a TCP socket stream with the DS. Or will I have to use regular linux socket calls. Is there any C++ examples using the WPILIB version? Also a concern of my is when I'm using the receive function will it stall the code until the server receives something?
Unread 03-04-2016, 23:03
Peter Johnson Peter Johnson is offline
WPILib Developer
FRC #0294 (Beach Cities Robotics)
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
The issue you're running into with mingw32 is likely lack of support in mingw for std::mutex. See https://github.com/meganz/mingw-std-threads for a possible solution (however, it will require editing a number of the ntcore source files). Alternatively if you can use mingw64, which may have the necessary support built in.
If you're rolling your own, the two classes you're referencing are actually part of ntcore, and while they're present in the library and docs, headers aren't installed for them at present (you can however copy the necessary headers from the ntcore source), and as they were actually intended for ntcore-internal usage, there's no examples. These two classes are pretty basic wrappers around Linux socket calls. Yes, accept() and receive() are blocking calls (although you can specify a timeout for receive to make it semi-non-blocking), so you should put them in a separate thread.
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
