How can angle offset of a shooter be calculated from pixel offset?
My team's robot has a high goal shooter on a turntable. Using our vision system, I need to figure out how far off-target the shooter is in degrees. I've been working on this for most of today without much luck.
Things I know:
The camera is in the middle of the shooter. I'm using OpenCV with Python, if that's useful. |
Re: How can angle offset of a shooter be calculated from pixel offset?
Figure out the lateral FOV of the camera in degrees, and calculate proportional to that using the known width of the image in pixels. Last edited by Oblarg : 02-04-2016 at 17:04. |
Code:
def get_offsets(bb_leftside_x, bb_width, img_width):
middle = bb_leftside_x + (bb_width / 2)
pixel_offset = middle - img_width / 2
angle_offset = pixel_offset * (26.5 / (img_width / 2)) # Raspberry Pi camera module FOV is 53 degrees
ret = {
"pixel_offset": pixel_offset,
"angle_offset": angle_offset,
return ret
https://imgur.com/RelZro4 |
You clearly calculate angle_offset right in that code...
Are you asking how to make a PID loop to turn the robot? |
If we look at this drawing from an earlier post, both lines (which represent pixel offsets) are 100px long. With the function from before, both would return the same angle offset since the function doesn't account for distance away from the target. |
Distance away from the target doesn't matter, that's precisely why you're measuring in angle (a dimensionless quantity) and not in distance. Imagine the camera at the origin, pointing in the +y direction. Place your target off to the side somewhere. How far off-center your target will appear in pixels is proportional to the angle between the line from the origin to the target and the y axis, not to the distance from the point to the y axis. To see this, place one target at (1,1). Place another target at (1,2). These are the same distance from the y-axis, which is the centerline of the camera's FOV, but they will clearly appear at different distances from the center when viewed from the camera, because the camera is a point at the origin and only sees along rays that pass through it. For an even better demonstration: Cover one of your eyes, align your other (open) eye with the center of your computer screen. Place your finger between your face and your computer screen, so that it overlaps with the edge of the screen in your vision. Notice that your finger is closer to the centerline between your eye and the center of the screen than the edge of the monitor is, despite the fact that they appear the same "distance" away in the 2d image that you see. The fundamental confusion here is that you're thinking in terms of rays parallel to the center-line of the camera. But that's incorrect, because those rays never reach the camera. Think of the camera as a point, not as a screen. All the rays that the camera sees must pass through the point. Thinking this way, it is clear that "distance" in the image the camera sees corresponds to *angular* distance. To preserve apparent "distance" between two objects from the point of view of the camera, you must preserve their relative angular positions. Last edited by Oblarg : 02-04-2016 at 20:51. |
If you want to aim to the center of the target than obtain the center x of the target and rotate to it using the formulas postEd.
In the photo posted, the left edge of the target is roughly at x=0 (assuming a graph is overlayed) and the right boundary is at x=x for the "far" target and x=2x for the "near" target, meaning the centers would be at x=1/2x and x=x respectively. The "near" target will request twice as much turning. Also please stop using the word turntable |
It's fairly simple. It's (pixels from center) / (camera pixel width) * FOV
For example, your camera has a field of view (FOV) of 45 degrees, your camera width is 320 pixels, and your image is 16 pixels off center. Then the angle to aim is: (320 pixles/16 pixels) * 45 degrees = 2.25 degrees You can calibrate your exact camera FOV by pointing your camera at a white board and marking two points on the white board at the left and right edge of the camera image. Then measure the distance between the two points on the white board, and the distance between the white board and the camera. Then a little trig will give you the FOV. |
#10
If your method described above doesn't seem to give you quite the right answer, perhaps you really want to know what the proportionality constant (pixels to degrees) is for small angles (rather than the full image width). To do this, I suggest:
This will give you the number of pixels per degree for small angles near the center of the camera image. |
#11
Screen steps live 2016 explains how to do this. https://wpilib.screenstepslive.com/s...ng-the-targets
