Go to Post During the year I can't wait for the game hint to be released, but then as soon as it is released and I read it for the first time my head starts to hurt and I regret reading it at all... - Jon Jack [more]
Unread 03-04-2016, 15:54
first_newbie first_newbie is offline
FRC #1718
first_newbie is a jewel in the roughfirst_newbie is a jewel in the roughfirst_newbie is a jewel in the rough
Reducing Colson Wheel Diameter
How would one go about reducing colson wheel diameter? This would be done so that a center drop would not be need to be made.
Unread 03-04-2016, 16:13
Richard.Varone's Avatar
Richard.Varone Richard.Varone is offline
AKA: Rich Jr.
FRC #0271 (Mechanical Marauders)
Richard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really nice
Send a message via MSN to Richard.Varone
Re: Reducing Colson Wheel Diameter
It's funny you ask, all you need is a Lathe, File, and caliper!
http://i.imgur.com/i1vMoVE.jpg
http://i.imgur.com/UbcVnva.jpg
All you do it stick a piece of hex shaft into the lathe, slip a locking collar on, put the wheel in, turn the lathe on and hold a file to it.
We did this for ~100 wheels, they where turned from 3" to 2.9" and 2.7"
2016 FLR (Excellence in Engineering)
2015 NY (Regional Finalists) & LI (Quality Award)
2014 NY (Regional Finalists, Quality Award) & LI (Regional Finalists, Quality Award)
2011 LI (Regional Finalists, Innovation in Control)
2010 LI (Regional Champion, Engineering Excellence, Coopertition Award) & NY (Regional Finalist)
2009 LI (Innovation in Control) & NY (Creativity Award)
2008 LI (GM Industrial Design) & NY (Innovation in Control)
2007 LI (Delphi "Driving Tomorrow's Technology")
2006 LI (Regional Champion)
2005 LI (Regional Finalist)
2004 SC (Regional Finalist)
2003 LI (GM Industrial Design)
2002 CMP (Division Finalist - Newton)
2001 NY (Imagery)
Unread 03-04-2016, 16:14
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Does the colson have a hex built into it? If so just take a 1/2 shaft with some sort of bolt/snap ring on the end. And just use a lathe to reduce the diameter.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 03-04-2016, 16:16
AKA: Rich Jr.
I'm not sure if you've had different results, but for us normal lathe tooling didn't work very well and found that a file worked the best.
2001 NY (Imagery)
Unread 03-04-2016, 17:15
R.C.'s Avatar
We used super small radius/sharp carbide insert that we normally use for aluminum. Works pretty well but I can see a file working pretty good as well or some misc HSS tool.
R.C.
Unread 03-04-2016, 17:23
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
If your wheels are spinning at the same RPM, wouldn't this cause issues with the actual contact speeds of the wheels being different? It seems to me that the larger center wheels would lose traction often and cause your drivetrain to "skip" or at least decrease the smoothness of the drive.
Unread 03-04-2016, 17:52
FarmerJohn FarmerJohn is offline
Pre-Rookie team
AKA: John Reynolds
no team (Turlock Titans)
Team Role: Team Spirit / Cheering
Rookie Year: 2016
FarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond repute
I wonder if a file would add a tread pattern onto the colson, or if a better effect can be achieved with a knurling tool.
Unread 03-04-2016, 18:14
DonRotolo's Avatar
Back to humble
FRC #0832
I don't think a knurling tool will work in a soft material such as colson tread
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
We worried about that in 2007, with an extra layer of tread affixed on the center wheels of our six-wheel-drive (it didn't have a drop on the axle). If anything, it made the robot drive more smoothly. We never decided exactly why that was.
Unread 03-04-2016, 18:21
Chris is me's Avatar
AKA: Pinecone
You need to use a very sharp tool to avoid just ripping up the wheel, but it can be done. For this case, I'd just use a file since you are taking off so little and you want to take off *just* enough for smooth turning but no more than you need to.
The very, very small diameter changes required to make this work would have a negligible effect on speed - seriously, this is taking about around 1/16th of an inch off the diameter of a wheel, maybe 1/8 if you're pushing it.
Unread 03-04-2016, 18:28
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
I'll hazard a guess:
The larger wheels spin faster, and exert more traction force because they support more of the robot's weight. That means a slight drag at the smaller wheels, which will be toward the rear in a 6WD because the front smaller wheels are lifted by torque. Rear drag opposes turning, making the robot feel smoother to driver.
Richard Wallace
since 2003
Unread 03-04-2016, 19:38
ollien ollien is online now
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Get that man some safety glasses! Not that I've never been guilty of doing the same thing in a hurry.
Unread 03-04-2016, 22:14
Rookie Year: 2013
Ok, thank you for the explanation.
