Go to Post This is an engineering competition. Do some. - JVN [more]
Unread 03-04-2016, 20:46
balloman balloman is offline
Sophomore Programmer
AKA: Bernard
FRC #0034 (Rockets)
Rookie Year: 2016
balloman is on a distinguished road
Command and Control
Since my team isn't going to nationals, and we have finished all our regionals, I decided to look into using Command and Control next year with LabVIEW. I use the simulation and it works great. My only problem is that all the other commands work, but any of the commands I make myself seem to run and then the driver station says no robot code. Any help would be appreciated.
Unread 04-04-2016, 15:21
JeffB JeffB is offline
FRC #5052 (RoboLobos)
Rookie Year: 2014
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
Re: Command and Control
It's pretty hard to see what's happening without code to look at.
There's only a single subsystem that comes with that code.
Are you running this by hitting the run arrow or building it and running it as a startup?
Do you see any errors pop up?
Are you running the entire robot or just the command on its own?
Unread 04-04-2016, 20:16
AKA: Bernard
FRC #0034 (Rockets)
Rookie Year: 2016
I run this with the run arrow from robot main, because that is how you run the simulation.
Whole robot
No errors
Unread 04-04-2016, 20:45
The code your added to the controller, and the command look fine. How do you run the command? One pretty big difference is that you are using the gyro. I will have to test how well it works in the simulator.
You may want to check your Begin VI to see if the configuration of the gyro looks right.
Greg McKaskle
Unread 04-04-2016, 21:03
AKA: Bernard
FRC #0034 (Rockets)
Rookie Year: 2016
Greg McKaskle
Well, I assumed that I would open the Gyro in Drive Controller.
Unread 04-04-2016, 21:20
Whoops. You are correct, that is the right way to do it.
And I need to get some rest before answering more questions.
Greg McKaskle
