Go to Post when things start to get a little stressful, "FIRST: Fun Is Required. So Tolerate!" - Rich Kressly [more]
Unread 04-04-2016, 21:24
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
Rookie Year: 2013
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Talon SRX magnetic encoder issues
I've been having a strange issue with the SRX mag encoders, sometimes leading to rather catastrophic results.
Running them in absolute mode, I've seen an issue where the reading seems to unexpectedly jump. For example, we're driving around the robot, and then one of the encoder readings suddenly jumps from 0.8 to 1.8 (measured in rotations). So it jumps up by exactly 360 degrees, and then the motor tries to unwind the extra full rotation. And when this happens, things rotate too far, wires get ripped out, and all sorts of Bad Things™ ensue.
I was never able to reproduce the issue in the pits, so perhaps it was an issue that arose with the robot getting beaten around on the field.
Does anyone have any ideas as to what could be causing this odd behavior?
Head Programmer / Driver
Unread 04-04-2016, 22:02
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Re: Talon SRX magnetic encoder issues
Do you need the rollover feature? If not, just take the decimal part of the rotation count and discard the rollover (everything to the left of the decimal).
If you do, send Omar a passive aggressive email telling him to fix the rollover feature (or just write it yourself while discarding the rollover that the talon gives you)
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
Unread 04-04-2016, 22:31
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
More detailed info would be helpful.
What exactly are you measuring with this encoder? It sounds like it might be steering angle of a swerve wheel? But that's just a guess.
What is the max angular speed the encoder will see in this application?
In normal operation, does the encoder cross the 360/0 discontinuity?
And just to be perfectly clear, the encoder is wired directly to the SRX, right?
Unread 04-04-2016, 23:01
cjl2625's Avatar
apel py
AKA: Cory Lynch
Rookie Year: 2013
1. It's a rotating cage that holds the ball. Video for reference
2. Rotates fairly slowly, it should take several seconds to go one rotation.
3. No, I've made sure that it doesn't cross
4. Yes
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
Rookie Year: 2012
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Check for CAN bus errors in the driver station logs when you notice this happening. I may have noticed something similar, but it didn't affect our design so we didn't looked into it very hard.
Also is the positioning loop running in the Talon SRX or the RoboRIO?
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 04-04-2016, 23:03
cjl2625's Avatar
apel py
AKA: Cory Lynch
Rookie Year: 2013
It's running in the SRX.
Unread 04-04-2016, 23:15
Ether's Avatar
Rookie Year: 1969
So to be clear, the encoder is mounted to the cage?
Unread 04-04-2016, 23:16
Rookie Year: 2012
Moving the loop to the RoboRIO would allow you to just use the above mentioned decimal portion of the encoder position.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 05-04-2016, 07:11
cjl2625's Avatar
apel py
AKA: Cory Lynch
Rookie Year: 2013
The encoder is integrated right into the versaplanetary gearbox that rotates the cage.
RyanShoff: that could be a good idea, I'll try that if I can't figure out how to fix it directly.
Unread 05-04-2016, 10:04
Ether's Avatar
Rookie Year: 1969
Does the encoder rotate at the same speed as the cage?
If not, what is the max angular speed the encoder will see in this application?
Unread 05-04-2016, 10:18
cjl2625's Avatar
apel py
AKA: Cory Lynch
Rookie Year: 2013
Yes, it should be rotating at the same speed.
Unread 05-04-2016, 14:18
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
It sounds like you have a cabling issue between the magencoder and Talon.
You can confirm this by grabbing the self-test before and after reproducing the problem and observing that the absolute position (pulse width) and relative position (quadrature) disagree. That's one of the benefits of the CTRE magnetic encoder; you have two references that rely on different physical wires.
Most likely the ribbon cable needs to be replaced, or if you are using a breakout inspect the solder contacts/wiring.
Are you close or exceeding the peak rated RPM for CTREMagEnc_Absolute? If so then select CTREMagEnc_Relative and setposition() to what the absolute reading reports. See github examples/Talon SRX Software Reference manual for more info and peak RPM specs.
Unread 05-04-2016, 14:28
cjl2625's Avatar
apel py
AKA: Cory Lynch
Rookie Year: 2013
The rotation is quite slow, so I don't think exceeding RPM is an issue.
At some point, I switched to relative mode and the problem stopped. So perhaps you are correct.
But we have two components robot using a mag encoder, and I've seen the same issue in both of them, so I figure it would be unlikely for them both to have the same cabling issue.
Unread 05-04-2016, 16:16
Ether's Avatar
Rookie Year: 1969
Are you sure the encoder is spinning at the same (slow) rate as the cage itself? Or is there a gear ratio between them?
