Go to Post In no way is my team a powerhouse but we're striving to compete among the top competitors and in my opinion that's a start. - rcmolloy [more]
Unread 05-04-2016, 19:52
AMendenhall AMendenhall is offline
FRC #3925
AMendenhall is an unknown quantity at this point
RoboRIO Imaging Fail
We are reimaging a roboRIO which has worked for the entire season.
After testing with and without internet connection, with both USB and ethernet connection to the roboRIO, and with the verified correct image version (v19), we cannot resolve this error:
Unable to download image to target. Unable to complete operation because of unexpected error:nisyscfg.lvlib:Format 5.3.vi:2890001<APPEND>
<b>Complete call chain:</b>
RoboRIOImagingTool.lvlib:Reconfig Device.vi
RoboRIOImagingTool.lvlib:ImageManager.vi
RoboRIOImagingTool.lvlib:ImagingToolMain.vi
I guess Windows 7 doesn't support html tags in it's error dialogues
Unread 06-04-2016, 00:04
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Re: RoboRIO Imaging Fail
Usually thats due to you powering down the robot while flashing firmware or image...
you can try booting it in safe mode and imaging it from there but if u get a "software error" message in the webdash than you may have bricked it
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
Unread 06-04-2016, 00:57
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
If this is the case I would suggest getting NI on the phone. They have ways to turn pieces of clay back into functioning electronics that are not available to teams or even CSAs.
Unread 06-04-2016, 19:56
FRC #3925
Thanks for the quick replies.
I talked with National Instruments today, I was given an extension to use tomorrow, when a different associate would be there.
If worst comes to worst, I'll take it to the booth they have at worlds.
Unread 06-04-2016, 22:45
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
Originally Posted by rtfgnow View Post
even CSAs.
With wise choice. If we had access than I'd probably forsee some CSAs (myself...... included? ) following the mindset of "Auton not driving far enough? Reinstall the FPGA on the RIO. Fixed!"
Unread 07-04-2016, 10:19
granjef3's Avatar
granjef3 granjef3 is offline
Code Ninja
AKA: Matt
FRC #2383 (Ninjineers)
Rookie Year: 2016
granjef3 is an unknown quantity at this point
Same thing happened to us when flashing a roborio and it lost power during the process. NI has a process to unbrick using a usb stick to flash firmware, if you call they will help you out.
