Go to Post I don't know about the rest of you but our robot was 100% built by team 226. Our team consists of students, parents, teachers, engineers, and alumni. - Matt Reiland [more]
Unread 05-04-2016, 21:08
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
TapeMeasure Climber Dropping after Match End
We are attempting a tape measure climber system for our regional this week. We are essentially using two 775 pro motors to extend and retract the tape measure. (we are using the tape measure itself to climb).
One major problem we are having is staying up, after the match ends and the power is cut. The weight is too much for the 775 pros and the gearing to hold with no power, and the bot quickly slides back down. What are possible solutions to remedy this?
Thanks in advance
Unread 05-04-2016, 21:09
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: TapeMeasure Climber Dropping after Match End
Passive hooks roughly on where your robot wants to stop.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 05-04-2016, 21:11
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Could you elaborate please. Thanks!
Unread 05-04-2016, 21:20
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
Mentor
FRC #4587 (Jersey Voltage)
Rookie Year: 2011
Clayton Summerall is on a distinguished road
Could you post pictures of the climber? It could be an easy fix.
Unread 05-04-2016, 21:30
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
I am at home, but I just texted some guys still at the shop to send some pics, i'll post as soon as I get them. But to describe, the tape is rolled onto a wheel (essentially how it is in the inside of a normal tape measure), but we have two 775 pros geared together to roll that wheel in and out so the tape is extended and retracted. The tape is held onto the wheel by a bunch of 3d printed rollers on the outside, applying constant pressure, and guiding the tape in a straight line.
Unread 05-04-2016, 22:10
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
Rookie Year: 2011
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
i secound the ratcheting mechanism, we have ours attached to a servo, that locks it in.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 05-04-2016, 22:11
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
What material are you using as the ratchet (is that what its called?...)
Unread 05-04-2016, 22:20
CalTran's Avatar
Missouri S&T Senior
Rookie Year: 2010
Usually teams cut off half of a ratchet wrench.
Unread 05-04-2016, 22:34
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Usually tools are not left in the robot on purpose
Unread 05-04-2016, 22:35
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
And when they are, you either find a random wrench on the field.... or very baaaad things happen.
Unread 05-04-2016, 22:46
Mentor
FRC #2587
Rookie Year: 2011
Yes!
We look forward to seeing your robot scale at Lone Star. Safe travels.
Unread 07-04-2016, 03:26
PeeDiddy PeeDiddy is offline
FRC #3863 (Pantherbotics)
Team Role: Driver
Rookie Year: 2014
PeeDiddy is an unknown quantity at this point
A simple way to eliminate back drive would be to toss a worm gear (looks like twisty pasta) in the gearbox.
Unread 06-04-2016, 11:49
who716's Avatar
Rookie Year: 2011
We had these solid steel ring hanging around that we cut off our gearboxes every year. We machined ratcheting slots into this and attached it directly onto the shaft In which the winch pullies are on. Then we attached a servo to a piece of metal so that when the winch is pulling down the ratchet rides over the servo but when it goes up just a second the ratchet locks in. The spring is simply to prevent the robot from falling if power is cut to the servo for any reason specifically the end of the match and we didn't fully climb the spring overrides the servo and locks the ratchet
Unread 06-04-2016, 12:26
Cam_Team 2619's Avatar
Cam_Team 2619 Cam_Team 2619 is offline
Director/King of The Mill
FRC #2619 (The Charge)
Team Role: Mechanical
Rookie Year: 2014
Cam_Team 2619 is an unknown quantity at this point
If you would like some help with a pneumatic disc brake, our team used one to stop our lift from backdriving last year, and therefore I have a fairly good understanding of how it works.
2014 - King of The Mill
2015 - Mechanical Co-Lead/Human Player Backup
2016 - Mechanical Lead
2017 - Director
  #15   Spotlight this post!
Unread 05-04-2016, 21:56
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Here are some pics: http://imgur.com/a/91JcU
