Go to Post We were all rookies once, and we really have two ways to go about things: either take a page from the powerhouses and emulate their style, or complain about not having anything and risk falling into oblivion. - George A. [more]
Unread 07-04-2016, 18:56
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
Rookie Year: 2014
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
Non-SIGNAL LEVEL power on custom circuit boards
Do any teams have experience with running non-SIGNAL LEVEL power through a homemade circuit board? Do inspectors care that circuit board traces and jumper wires mat not be meet wire gague requirements? We are building a circuit to control common-anode LEDs via MOSFETs controlled off an Arduino. The while thing is powered off a secondary VRM.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 07-04-2016, 21:21
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Non-SIGNAL LEVEL power on custom circuit boards
LEDs, with a typical current consumption in the tens of milliamps, would be a signal-level power circuit in my opinion. Or to put it another way: What size wire would safely carry the current actually needed? If it's less than 26 AWG, it is signal-level.
Of course, my opinion is worthless at a competition.
Unread 07-04-2016, 21:46
jnicho15's Avatar
AKA: Dan
Rookie Year: 2014
It's powering a few meters of led strip, so it takes about 0.5 to 1A.
Unread 07-04-2016, 23:31
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
R49 says the 500 mA outputs of the VRM are SIGNAL LEVEL wiring.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 08-04-2016, 13:57
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Max,
Yes, I hate that rule for that confusion.
Yes, we care about the wire gauge for what protection device it is using. If your are connected to the 2 amp output of the VRM, then you must have 22 AWG as the power wiring. If you are running smaller than 2 amp circuit traces, then those traces become the secondary fuse. We know that if the wire feeding your custom circuit were to short, the protection would prevent that wiring from catching fire. If you were to feed a string of LEDs with #36 wire, then we know that the wire shorting would likely produce some short duration fire, flame and smoke but that the VRM and then the breaker or fuse feeding that module would act to protect the wiring feeding the module.
Al
WB9UVJ
www.wildstang.org
________________________
