Go to Post Here's my standard for-every-new-member-of-Chief-Delphi-Welcome: WELCOME TO CHIEF DELPHI!!!!!! :D - [more]
Unread 08-04-2016, 00:37
quillford quillford is offline
FRC #5924
Rookie Year: 2015
quillford is an unknown quantity at this point
I2C IMU Java question
We have this IMU from AndyMark. I didn't see any WPIlib (Java) documentation for it. Does it need an arduino or can we directly connect it to the roborio?
Unread 08-04-2016, 07:51
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: I2C IMU Java question
We have not used that physical packaging. However, it looks like your unit contains an ITG-3200 gyro. We did connect an ITG-3200 gyro directly to our roboRIO in 2015. The following link it to the Java package containing the code we used to interface with it (you will probably need the GyroAdapter as well as the ITG3200).
https://github.com/frc868/frc868-lib...ds/lib/sensors
Hope that helps.
