Go to Post Cooling fans? Never had the need. Then again, we're talking New Jersey in March. Radiant heaters might be a better choice, or maybe snow boots. - DonRotolo [more]
Unread 08-04-2016, 12:30
Chris Hapstack's Avatar
Chris Hapstack Chris Hapstack is offline
Design Mentor
FRC #0342 (Burning Magnetos)
Rookie Year: 2007
Chris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to behold
pic: Magnetic Grappling Hook
Unread 08-04-2016, 12:31
Design Mentor
Rookie Year: 2007
Re: pic: Magnetic Grappling Hook
Latching: https://www.youtube.com/watch?v=G6oYBItYZrU
Firing: https://www.youtube.com/watch?v=v3PiLsyRn10
2017 -------- Team 342 mentor (Charleston, SC)
2015-2016 - Team 85 mentor (Zeeland, MI)
2007-2010 - Team 281 student (Greenville, SC)
Unread 08-04-2016, 12:39
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I like the idea, definitely looks like it would help the claws engauge, though it does not appear to fix the problem of having to be basically perfectly lined up for it to catch. =/
Unread 08-04-2016, 13:00
Design Mentor
Rookie Year: 2007
Oh yeah it's definitely more of an amusing prototype at this point rather than a finished product. I was hoping the magnets would have a more dramatic effect, so we might end up going with something entirely different.
Unread 08-04-2016, 13:18
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Rookie Year: 2014
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Pretty sure the 20 second time factor would preclude that design
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 08-04-2016, 13:24
Design Mentor
Rookie Year: 2007
In what way? This (or a different grappling hook) would be entirely contained within our frame perimeter until the last 20 seconds of a match.
Unread 08-04-2016, 13:29
Rookie Year: 2014
The acceleration applied to get magnet to engage on bar is relatively slow. So to properly position (big one) , then engage, then collapse then winch seems like that would be troublesome to say the least in 20 seconds. Don't see how the magnet helps much.
Unread 08-04-2016, 13:36
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
I'm pretty sure the cables used to engage the winch clamps would also be used for the lift so the whole thing, so the grasp and lift portion of the process would be done in one action. Sure, positioning would take time but could be done before the 20 second mark. Winding in the winch could be done quite rapidly depending on the motor and gearing used (a decent PTO could probably climb in less than 10 seconds).
IMO the biggest issue with these types of designs is accuracy, if you can get past that, you probably have the most effective type of climber out there.
Unread 08-04-2016, 13:43
fiona.crush1011 fiona.crush1011 is offline
AKA: Fiona Hanlon
FRC #1011 (CRUSH 1011)
Rookie Year: 2010
fiona.crush1011 is an unknown quantity at this point
Do you have any close-up pictures of the real mechanism?
Unread 08-04-2016, 14:02
Design Mentor
Rookie Year: 2007
Yes, the same cable both engages the clamps and lifts the robot. Our winch is designed to run at 12 inches/second under the load of the robot's weight, so we could ostensibly complete the climb within 4 or 5 seconds of firing the hook. Accuracy is definitely the biggest hurdle yet to go.
Unread 08-04-2016, 13:57
Rivet Man Rivet Man is offline
AKA: 97525A425
no team (Better than Bolts)
Rookie Year: 2014
Rivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond repute
Hi Chris Hapstack,
I'm going to agree with my friend Boltman on this one.
This design sure looks entertaining but it reminds me a lot of those arcade games where you try your best to win a stuffed bear but always end up dropping them even though it looked like you lined 'em up (Sorry Linda!).
I guess the positive here is that you could have your driver practice hanging by trying to win toys out of those machines. Just 20 dollars of practice and they'd be pros!
On another note, all that stuff still comes under 1 pound? Do you guys design these robots out of air or something? If I bought a clamp like that at Home Depot it'd weight at least 5 pounds!
Best Regards,
RM
Unread 08-04-2016, 14:05
Design Mentor
Rookie Year: 2007
Delrin, polycarb, and a little aluminum! I can't promise it'll lift much more than a robot, but it's looking like it will support ours.
Unread 08-04-2016, 14:27
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is online now
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Oof I'd be careful with that I've seen a few magnets explode when they collide with something too hard. It is quite a spectacle unless said magnets are expensive rare earth magnets you just recently purchased.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 08-04-2016, 14:30
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Any magnet with a metal coating would work as well I would think.
  #15   Spotlight this post!
Unread 08-04-2016, 14:37
Then I guess my only real concern is if it accidentally went off and it happened to land in another robot.
