Go to Post Andy, you have daughters, would you buy them a Dave doll? - MissInformation [more]
Unread 09-04-2016, 20:49
medofbr medofbr is offline
FRC #5404
medofbr is an unknown quantity at this point
Dlink DCS-933L connecting to roboRealm
Hello,
I am trying to use a D-link DCS-933L ip camera with Roborealm for my team's vision code, but I can not get Roboealm to find the camera.
The camera is set up via its app and you can view its video feed through the phone.
Using the read HTTP command I used these settings,
Camera Type: D-link DCS-2102 (only d-link option)
Url: http://192.168.2.58/video/mjpg.cgi?profieid=1
Username and Password are put in
No HTTP Headers
Refresh Frequency:ASAP
Timeout: 1000ms
this does not work.
For the D-Link internet camera command:
ip Adress:192.168.2.58
Port: 80
camera TypeCS 900/920
This does not work either.
I tried this on the KOP router and a Belkin router but neither of these worked
If you know what I am doing wrong please reply
Thanks,
Ben
Unread 09-04-2016, 21:04
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Dlink DCS-933L connecting to roboRealm
Is the IP on the computer that RoboRealm is running on compatible with the default camera IP address you are using (e.g., 192.168...)?
Our standard FRC IP addresses are either 169.254.... in the pit or 10.TE.AM... on the playing field.
Giving the camera a static IP compatible with your RoboRealm PC or setting it to use DHCP is preferable.
Unread 09-04-2016, 21:08
FRC #5404
The laptop's ip is 192.168.2.56
should i change both ip's to 10.54.04.2, 10.54.04.5 (or some other #)?
Unread 09-04-2016, 21:18
Just Itinerant
As long as they are compatible then I wouldn't worry too much about the IPs for now, just get things to work. Eventually you'll need to change them for competition.
You should be able to use a web browser to view the camera stream with the camera directly connected to the PC.
I haven't played enough with RoboRealm to be much help debugging that interface, but I'd suggest getting the standard one's to work first.
Unread 09-04-2016, 21:41
FRC #5404
Using settings in the browser got it to work!
Thanks.
