Go to Post Let's let FIRST bring us together as a whole rather than separate us into parts eh? - sanddrag [more]
Unread 10-04-2016, 14:09
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type is an unknown quantity at this point
Withholding Allowance & Michigan Championship
So this is going to be a two part question. Our welds on our arm are starting to break and to my knowledge, there is no welder for use at the event so I had the idea of welding a new arm to be safe. The problem is that it weighs 35 lbs so it won't fit within the withholding Allowance. We could do it in two parts and replace one part before State and the other before world's (if we go), but is the withholding Allowance the same? And would the arm count against the withholding Allowance since it would replace a part? It would be the exact same arm as before, just new.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 10-04-2016, 14:16
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Withholding Allowance & Michigan Championship
There might be some "cheats" you could do if the 35 includes things that could be COTS and put on at the event like motors, sensors, gear/chain, etc. If it's straight 35lbs of metal, you might be a little out of luck.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 10-04-2016, 14:28
Type's Avatar
Rookie Year: 2016
We may have to just replace parts. Thanks for replying though. We do have motors and mounts that won't change, camera and LEDs that won't change but I can't remember if we weighed it last time with or without the motors on it.
Unread 10-04-2016, 16:41
rich2202 rich2202 is online now
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
The Withholding Allowance is the "same" rule. You get 30# at State, and 30# at Worlds. they don't have to be the same 30#. So, you could replace part of your arm at State before you bag, and then rest at Worlds when you unbag.
Note: Time is very limited at Worlds (load in starts at 1:00 pm, Practice matches start at 6:00 pm, and Qualification Matches start the next morning). Given the mad rush at 1:00 pm, Estimate 2:30 pm to load in. That gives you 3.5 hours to uncrate the robot, get cleared to unbag, and modify your robot before practice matches start. Sometime before 8:00 pm, you need to get weighed and pass inspection.
Unread 10-04-2016, 16:43
Type's Avatar
Rookie Year: 2016
That was actually the idea I was thinking. I mentioned it to my coach and he said we would talk about it as a team on Tuesday so most likely nothing will get fixed until world's is the bad thing, but thanks for help on giving ideas.
