Go to Post School cannot teach everything you need to know so they teach you how to learn. - kstl99 [more]
Unread 12-04-2016, 14:30
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Re: Catapult issues with boulders
Originally Posted by tr6scott View Post
To me, the issue with the new balls is the stickyness of the coating, not squishyness of the ball. So it appears that you use a vacuum generator to hold the ball, the funnel and the hose. I do not know your sequence, but I would look at making the vacuum a little less effective with a new ball. maybe some slits in the funnel? Maybe releasing vacumm prior to shooting, then move arm? Maybe move the vacuum funnel towards the bottom of the arm.
We have nothing that fancy. The cup is simply a drip pan from a stove.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 12-04-2016, 15:27
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
would it make sense to increase air flow to the cylinders? would two solenoids per cylinder work (or even legal)?
Unread 12-04-2016, 15:29
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Are you using high flow solenoids? We used them in 2014 on our pneumatic catapult. To increase flow even further we allowed the return port on the cylinders to vent to atmosphere.
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
It's not legal. See R90. That being said, what's the flow rate of your solenoid?
Unread 12-04-2016, 13:40
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Quick observation - it looks like the one on the right sits higher in the catapult 'cup' or 'tray' than the other one. More of the ball is exposed rather than supported.
GitHub
