Go to Post Come on, guys, it's two weeks 'til build. Personally, I'm gonna go outside for a little before I forget what my neighborhood looks like in the daylight. :) - Libby K [more]
Unread 20-04-2016, 09:07
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
Team Role: Coach
Rookie Year: 2011
aeastet is an unknown quantity at this point
Re: Robot Drive Not Running Fast Enough - PLEASE HELP!
Try this one:
https://www.dropbox.com/sh/d12jln54w...k9WlFBo7a?dl=0
Unread 20-04-2016, 09:16
Programming Mentor
AKA: Tim Easterling
Team Role: Coach
Rookie Year: 2011
I edited a lot of things in your code. I added functional globals or action engines as I call them. I reorganized the timed tasks to make the dashboard updates less often. I then added the action engines to get the data that you collect and store it for use everywhere else in your code. I updated the teleop vi. I think there is still more we can do there but I wanted to get this into your hands now so you can start to see and try understanding what I did.
I started working on the auto mode. I got through a lot of it. I am trying to do my best to understand what you were doing.
Again let me know if there is anything else I can do to help you understand what I did.
Tim
Unread 20-04-2016, 10:42
This thread seems to be trending into a "alternative ways to write the same code" thread. But the original post was about performance. Nobody is talking about performance.
LV is a language. There are infinite ways to write something. There are tradeoffs to each of those solutions. Rewriting code to be different without measuring and addressing the goals -- in this case, performance improvement -- is not good engineering.
When I loaded the code several days ago, it was broken and I didn't have much time to spend on this. Has someone, anyone, run this code to make basic measurements? Without this data, everyone is making recommendations on hunches or past experiences. This doesn't need to be theoretical work.
Greg McKaskle
Unread 22-04-2016, 10:10
Programming Mentor
AKA: Tim Easterling
Team Role: Coach
Rookie Year: 2011
Hi Bradley,
Did you get a chance to look a the code I put together? Do you have questions?
Greg,
I do appreciate that sometimes code does not have to be rewritten if it works no matter if it uses good programming styles or not. It was not my intention when I started, to rewrite the code for this team. The more I dug into the code the more problems I saw. It seemed easier to fix the problems and make the code easier to read then to try to keep scrolling back and forth to understand the code. As I made things easier I found mistakes that I would not have found if I just let the code alone. They were calling a joystick that was never established in the begin file. They were call for a solenoid valve that was never established in the begin file. They were enabling and disabling some motor controllers in teleop. This is part of the reason the code was running slower than expected. Even if I did not change how the teleop timing was working the code is easier to read and easier to edit. I try to teach LabVIEW programming classes every summer to local teams in my area.
I also thought it would be a good opportunity to show them how to use proper programming techniques. This will help them write better more efficient, easier to maintain code in the future. I think LabVIEW gets a bad wrap around this forum because people feel that it does not work well. Part of the problem is that people are not using it to the best of its' abilities. LabVIEW is easy to use. That is a strength and a weakness. People think that they have figured out how to use LabVIEW just because they get something to work. I do not work for National Instruments but I have over 16 year of programming experience with LabVIEW and I try to help people see how easy and efficient it can be if done with good programming standards.
That is why I published our code every year and why I took the time to help these guys out.
Tim
Unread 22-04-2016, 16:15
I appreciate your willingness to help teams, and I don't doubt your abilities to write good LV code.
I was making the observation that this thread, like a good number of others, seemed to divert from the original question. More importantly, it is key to make measurements for topics like this one, and I didn't see any discussion, still don't see discussion of code performance -- other than adjectives such as faster.
Case in point, functional globals, or action engines if you want, can be quite a bit slower than a simple global, or they can be faster for some access patterns. They are a great technique to learn, but not necessarily for performance, and not necessarily required when a simple global is good enough.
Please don't let my comments dissuade you from helping teams with their programming. And a summer training course is a very ambitious project. Thanks for doing it, and good luck. Let me know if I can help in some way.
Greg McKaskle
Unread 20-04-2016, 08:51
Bradley Boxer's Avatar
Bradley Boxer Bradley Boxer is offline
AKA: Bradley Boxer
FRC #0303 (TEST Team 303)
Rookie Year: 2015
Bradley Boxer is an unknown quantity at this point
Originally Posted by aeastet View Post
I am working on a major upgrade to your code. Even if you choose not to use it you should look through it and try to learn from it. Do you have a place for me to put the code when I am done?
If you message me your email, I can add you to a google drive folder that our team has been using to transport and store code. Thank you!
Originally Posted by The_Waffleing
Is there any particular reason for doing that. another thing that you can do for your begin.vi is replacing the write global variable that you have going with a funcional global variable (FGV) since the only place your are needing all that information is in autonomous.
I don't quite understand how a functional global variable would help in this situation. We are only writing the variable once (in begin.vi), so why would the data need to be feed into a loop/shift register? Thanks for your help.
