Go to Post HAH! What else am I supposed to do on a weekend? Sleep? - Michael Hill [more]
Unread 13-04-2016, 00:27
FiM Informer FiM Informer is offline
Just an Honest Michigander
Rookie Year: 1992
FiM Informer has a reputation beyond reputeFiM Informer has a reputation beyond reputeFiM Informer has a reputation beyond reputeFiM Informer has a reputation beyond reputeFiM Informer has a reputation beyond reputeFiM Informer has a reputation beyond reputeFiM Informer has a reputation beyond reputeFiM Informer has a reputation beyond reputeFiM Informer has a reputation beyond reputeFiM Informer has a reputation beyond reputeFiM Informer has a reputation beyond repute
[FiM] Michigan State Championship Preview
Welcome to the most anticipated district event of the season! The 2016 Michigan State Championship is the second most selective event all year (24.8% of Michigan teams made it vs. 19% of world teams to the Championship), and the second most selective MSC of all time (2014: 23.1%).
I’d be remiss if I didn’t discuss how this selectiveness has changed Michigan FRC history. There are 12 teams that have qualified for every MSC: 27, 33, 67, 70, 494, 503, 548, 573, 1718, 1918, 2337, and 2834 (3539 gets an honorable mention, having made it every year since their 2011 inception). This set dropped in size by 2 this year, with 245 and 469 failing to qualify. 245 will attend the Championship anyway due to a regional win, but the Guerrillas will be missed in both Grand Rapids and St. Louis.
The last time fewer than ¼ of Michigan teams had the opportunity to attend MSC, FiM found a new venue to hold more teams. With FRC in Michigan continuing to grow at a prodigious rate, FiM must be looking for the next location, although I can’t think of many locations that could fit an event of that magnitude (ideally 140+ teams with the capacity for more).
For now, we return to Grand Rapids, the Deltaplex, and its 102 teams. Many of these teams have already been through the ringer. 48 of them will enter the elimination rounds, and 3 will emerge victorious. Lots of teams will come in feeling confident, and for most that’ll be snuffed out. A full ⅓ of the field (37 teams) has been the captain or 1st pick of a district champion alliance. That expands to 67 teams if you include all the captains and 1st picks of finalist alliances. No amount of accolades or medals can carry you through the Michigan State Championship. My strategy tips won’t carry you either, but maybe they’ll help.
Qualification Strategy
This section is pretty obvious because MSC-quality teams are pretty good. The breach is a given. With relatively little defense, captures will be crazy common. These assertions are supported by the aggregated TBA Insights data from the past three weeks of Michigan events as well as the three District Championships last weekend. As a region, PNW is probably similar to Michigan in strength (due to the crazy growth in Michigan the past few years). However, MSC is a much more selective district championship (25% vs 40%). Still, they're the closest point of comparison.
Most teams have preferred shooting modes (low or high, location), and they’ll stay with those throughout quals. Teams with a choice between going high and low will want to adjust accordingly to ensure the capture. With captures being common, winning the match will have more importance to seeding here than at any other event (even CMP). Still, even if captures were guaranteed in every match, there would still only be as much quals defense as a regular W-L-T seeding game.
Playoff Strategy
Strategy in elims has gotten more and more complicated throughout the season. There’s no single key to winning, no one piece of advice I can give you. In my search for answers I looked at the differences between district champion alliances and finalist alliances. At most events, the finals are competitive, and the finalists could have won if things had fallen their way.
I took a close look at how the performances of the alliances changed from the quarter/semifinals to the finals. Champion alliances averaged 7.87 balls and 46% capture rate prior to finals and 7.87 balls and 47% capture rate in the finals. Basically, they did exactly the same. Finalist alliances, however, dropped from 7.04 to 6.19 balls and 33% to 19% capture rate. What’s the takeaway? The best alliances are unaffected by any opponents and seem to avoid problems of random chance.
Finalist alliances typically have hit some critical pitfall. At East Kentwood, 2474 had a pair of drivetrain failures that knocked them out. At Woodhaven, 27 had a number of uncharacteristic misses (which you’d blame on defense, but they looked to have 50 lb on their defender). Maybe the most mind-boggling was the 40 points of fouls racked up by the Troy finalists in two matches. Once you add in the finals tortuga in Lansing, you start to get the picture. Winners avoid failures of all kinds.
If you’re an alliance captain, your choice for first pick will be driven by very conventional statistics/scoring output. Once you make it back for the second pick, however, you’ll have lots of similarly good choices (although likely as not no diamond in the rough like 3098 last year). In this case more than any other, you need to avoid failures from all your alliance members. If you’re not already scouting tortugas and robot failures (times when a robot ends a match unable to drive), you’re going to be behind your peers. Additionally, you’ve got to get a rock solid auton. Every team at MSC has the ability to score balls, but your third team has to be able to defend too, and be able to transition from one to the other when necessary. In some ways, the third team needs to play smarter than the top two bots, paying more attention to the clock and the score (not that I have any great suggestions for scouting this.. Maybe make potential partners’ coaches take IQ tests).
Power Rankings
As in previous years, I’ve polled 13 individuals, Michigan’s foremost experts as well as a few guest voters. Voters ranked their top 15 teams. Those teams were allotted points based on their ranks, with points decreasing from 18 points for a #1 ranking going down exponentially to 6 points for a #15 ranking (yes, this is pretty arbitrary). Here are the results:
Team (First place votes) - Points - Commentary
  1. 33 (7) - 204 - There’s not much to say about the Bees. They excel at every facet of the game (with the exception of a great shooting auton). They’re fast, they grab the ball well, they score the ball well, and they go up at the end of the match real quick. Everybody else has a ways to go to catch up.
  2. 67 (1) - 185 - The new shooter isn’t 100% but it very well might be at MSC. They’ve got a nice scale too, but after that, I think this ranking has a tinge of hype. Despite winning both of their events, HOT has weaknesses, including their strong preference for shooting from the (most easily defended) middle batter ramp.
  3. 3357 (1) - 182 - The best of the west, the COMETS have a linkage arguably even more fun than 33’s intake. It’s a clever design that likely locks them into their midrange shooting position, but they shoot fast enough that it might not even matter.
  4. 3620 (2) - 174 - In some ways the Joes are a robot in the same mold as the Bees, but they trade in scaling for an effective auton shot.
  5. 2771 (2) - 171 - Code Red set the world high score at East Kentwood, then tried moving their shot back to the outer works at Ann Arbor. It wasn’t a home run, but they picked up a blue banner and will keep working on it.
  6. 27 - 139 - RUSH checks in as the first tall bot on this list (is it just me or do they look like a yellow 1241?). Thwarted in the finals of 2 out of 3 events, they’ll hope to dial in their shots and pair with somebody small and speedy to compensate for their own leisurely pace.
  7. 2767 - 116 - Twice above average partners for the Average Joes, 2767 hopes to get out of that shadow and make their mark. If Stryke Force can find a way to pair with another outer works shooter, they’d make a nearly undefendable alliance.
  8. 85 - 113 - BOB is another team that’s been working on hitting the outer works shot. They’ve also got more medals this year than any other team in Michigan, having earned all four medalled awards (Champs, Finalists, CA, EI).
  9. 107 - 109 - 107 got the result you always want at West Michigan, where they knocked off the #1 alliance for the district win. However, they suffered accuracy problems and will hope to improve in that area.
  10. 2834 - 105 - They’ve got an accurate vision-targeted shot, but it’s from midrange and not tremendously fast. Have to imagine a good defender would wreak havoc if they don’t move that shot forward or back.
  • Honorable Mentions (more than 70 pts): 1023, 1918, 2054
Unread 13-04-2016, 00:40
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Re: [FiM] Michigan State Championship Preview
We may only be 75th in the state after two disappointing quarterfinal rounds, but I promise that our first ever MSC elimination performance will be one to remember. (well, maybe. Unfortunately, 7 kids can't do a whole lot)
Yeah, from what I heard they lost a few good mentors but I hope that this season will be a learning experience for the more motivated students on the team to learn what it is like to lose and come back next season ready to outperform their former selves.
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
Unread 13-04-2016, 08:56
Jim Schaddelee's Avatar
Jim Schaddelee Jim Schaddelee is offline
Team 107 Holland Christian / Metal
None #0107 (Team Robotics)
Team Role: Mechanical
Rookie Year: 1997
Jim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud of
" 107 got the result you always want at West Michigan, where they knocked off the #1 alliance for the district win. However, they suffered accuracy problems and will hope to improve in that area."
First, thanks for the great insight on the MSC. It is great when mentioned and motivating when not, it always a win win. Our team accuracy problem had more to do with the boulder going through one side and out the other, which I think we have fixed. Our bigger problem was the speed in which are arm would raise, also fixed. These were simple fixes. So, with a few week from our last competition team 107 decided to " hang out" and make some improvement to the end game.
https://youtu.be/llLjAPCKATc
Team 107 Holland Christian / Metal Flow
2005 Midwest semi finalist
2005 Johnson & Johnson sportsmanship (midwest)
2005 West michigan Champs with 93 and 66
2005 Johnson & Johnson sportsmanship (west michigan)
2005 web site award
Unread 13-04-2016, 09:53
JackN JackN is offline
AKA: Jack Nowakowski
JackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond reputeJackN has a reputation beyond repute
A few things have really stood out to me this season within the state and they are all sort of tied together. I have been really impressed by the emergence of a few of the younger teams from the west side and northern areas of the state and how it appears to have shifted the balance of power from the Southeast Michigan teams. 3357, 3620, 2771, among others have really emerged this season and have really pushed the region to improve by leaps and bounds. I think this improvement will really play out at MSC. Last season I thought the move to expand the event left it pretty diluted and I think there was a little bit of a drop off in quality in the back half of the draft at the event. This season that will definitely not exist. There are going to be some VERY strong teams falling to the bottom alliances on the draft.
The increase in districts has really helped raise the bar of the second tier of teams. Where before some of the younger teams would go years without ever getting the chance to captain an alliance, adding so many events has given these teams more chances to improve and learn the intricacies of playing deep into eliminations. Learning how to win is an important skill for teams to develop and they are getting more and more chances to do so. This is going to play out with a bunch of new teams captaining alliances at the state. The ones that can correctly identify how the eliminations will play out and adjust their alliances accordingly will be rewarded.
2005-2007 Team 494 (Lead Scout and Strategist)
2008 Team 70 (Drive Coach)
2009-2011 Team 1504 (College Mentor)
Unread 13-04-2016, 10:02
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Originally Posted by Jim Schaddelee View Post
107 decided to "hang out" and make some improvement to the end game.
Very nice jam!
Richard Wallace
since 2003
Unread 16-04-2016, 00:45
James Juncker's Avatar
James Juncker James Juncker is offline
Broken Robot Fixer
FRC #2834 (Bionic Black Hawks)
Team Role: Driver
Rookie Year: 2012
James Juncker will become famous soon enough
Hmm so 2834 has a slow vision tracking shot huh... I'd like to say that no, we aren't using vision tracking in teleop and secondly we had proven that we can move our shot around and finally, did I mention that auton works now should be interesting to see how the predictions match up!
2012 - member of 2834
2013 - electrical and mechanical function
2014 - driver, mechanical, and drivetrain
2015 - driver, drivetrain, mechanical knot tying
2016 - captain, mechanical, drivetrain
The FRC season has 3 steps
Eat
Build
Play
It is important to note that sleep is not included in these steps.
Unread 16-04-2016, 06:28
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
Originally Posted by James Juncker View Post
Hmm so 2834 has a slow vision tracking shot huh... Personally I'd say that no, we aren't using vision tracking in teleop and secondly we had proven that we can move our shot around and finally, how is 8 balls on our own slow again? Last I checked that's just as fast as code red and comets in the world record match, did I mention that auton works now should be interesting to see how the predictions match up!
One match means nothing. In one match my 5460 kids cycled 10 by themselves. Doesn't mean they cycle 10 every match
Unread 16-04-2016, 08:31
FIMAlumni's Avatar
FIMAlumni FIMAlumni is offline
FIMAlumni has a spectacular aura aboutFIMAlumni has a spectacular aura aboutFIMAlumni has a spectacular aura about
There are so many amazing and close teams at MSC this year I'm going to make a bold prediction. The MSC Winners we be from a double digit alliance (10-16)
Unread 16-04-2016, 08:32
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
Doubt it. Only possible way is 33 and 67 since 2767 will pick 27
E/ totally misread that.
Still doubt it. So many good teams
Unread 16-04-2016, 09:36
FIMAlumni's Avatar
The amount of high level teams is why I think it will happen. Those back end alliances are going to get extremely impressive second picks.
Unread 16-04-2016, 11:06
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
I don't know if that matters all that much.
A high seeded Alliance might not get the best offensive robot of the bunch, but they can sure pick up a strong defensive one no matter where they are in the draft.
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
Unread 16-04-2016, 12:33
Doug Frisk's Avatar
Doug Frisk Doug Frisk is offline
Keeping Score
AKA: Doug Frisk
Rookie Year: 2011
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
30 of 208 Minnesota teams are invited to the Minnesota state championships this year. That's 14.4%
Unread 16-04-2016, 12:38
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
I'm pretty sure that FiM Informer was referring to in-season events.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 16-04-2016, 12:54
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
MSC Alliance selection results
Code:
1   2767    33  1684
2     27    67  1718
3   4003  1023  5114
4   5150  5460  2137
5   5980  2771  2054
6   4967  1918  3546
7     70   107  3665
8   3620  3357  3604
9   2474  4362  5448
10  494   3534  3770
11  5050  3641  1250
12  5053    85  2834
13  4391  3602  2586
14  3688  5505    74
15   573  3098   503
16  5048   548   217
No declines
The 25th seed became an alliance captain.
  #15   Spotlight this post!
Unread 16-04-2016, 13:15
Doug Frisk's Avatar
Keeping Score
AKA: Doug Frisk
Rookie Year: 2011
Octofinal? Shouldn't it be something like sesunciafinal.
Octo is 8, sesuncia is 1/8.
Semifinal, Quarterfinal, Sesunciafinal. Of course the next level would be semisesunciafinal which is a bit of a mouthful.
Apparently octofinal is what they use at the North American Debating Championships which means that this matter must be up for debate.
