Go to Post There are no easy answers... only complicated and never ending questions. - Shawn60 [more]
Unread 15-04-2016, 00:03
vigneshv vigneshv is offline
FRC #2489
vigneshv is on a distinguished road
New benchtop mill
Hi,
We are looking to buy a benchtop mill in the offseason. Does anyone have any recommendations on which mills would be best for FRC use? Our budget is around $5000. Thanks!
Unread 15-04-2016, 01:28
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: New benchtop mill
I'm just going to run through the standard CD checklist for mills:
1: Does it have to be a benchtop? Do you have room for a full knee mill like a Bridgeport?
2: You should probably count on spending at least as much on tooling as on the machine.
3: Do you have a mentor or a contact who knows how to use a mill? The nicest machine in the world won't do you any good if you don't know how to use it.
4: Whatever machine you get, it's probably worth taking it apart and cleaning it up. You can look up details for whatever model you end up getting online.
5: At some point, Cory might post in this thread. If he does, listen to what he says. He knows what he's talking about (much more so than I do).
6: The search feature is your friend. A quick search for "benchtop mill" produced a ton of results. Here are a few you might find relevant:
[1]
[2] [3]
It's definitely worth reading through some of these old threads-- most of the info is still relevant.
Best of luck with your search!
Edit: Based on those old threads, I'd look into a RF-45. Grizzlys work but... Well, the one in the metal shop where 2667 works is pretty much perpetually broken and the Bridgeport has been trucking since probably before I was born, so make of that what you will.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 15-04-2016, 01:32
Ian Good's Avatar
Ian Good Ian Good is offline
Senior Tech. Advisor
FRC #2930 (The Sonic Squirrels)
Rookie Year: 2012
Ian Good will become famous soon enough
This thread and this thread should be able to help you!
Also I did a little bit of digging around and I found this
That seems to be a decent mill with a Digital Read Out for really cheap (!!!)
I don't own one so I can not attest to the quality of the mill however we have been using Grizzly tools in our shop for years and we've never had a problem.
Unread 15-04-2016, 02:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
RF-45 is the highest quality readily available benchtop mill you're going to find. It's pretty pain free to use and can legitimately make good parts (especially with DRO), but it is small, doesn't have much z-travel, and changing tools can be annoying.
It's well within your budget, but you could also be looking at bridgeports/bridgeport clones with your budget, if you have space.
2001-2004: Team 100
2006-Present: Team 254
Unread 15-04-2016, 02:19
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Buy the most machine that you can afford and make space for, machine performance to price ratio is non-linear(eg. 2x$$$=4xMachine). If you want advice on tooling and/or buying a full sized machine used, please do not hesitate to PM me. Some people around here might say I buy too many machines >_>
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 15-04-2016, 02:21
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Seconded. The RF-45 has a dovetail column, which is a must IMO for drilling and milling on the same machine (which you will do). Whatever you go for, avoid round column mills.
Make sure you bolt these down, especially if you put them on the flimsy sheet metal stands they come with. I've found that as little as turning the handles too fast makes it shake and throws it off as much as 0.005" on the spindle.
<Now accepting CAD requests and commissions>
Unread 15-04-2016, 03:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Who makes the best Bridgeport clone these days?
Unread 15-04-2016, 08:23
protoserge's Avatar
protoserge protoserge is online now
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
Why benchtop when you have budget for a knee mill? Is tooling factored into the budget? A knee mill isn't much more of a footprint on the largest benchtop type.
PM-940 from machinetoolonline.com would be my recommendation if you have to get a benchtop type. Ask about getting a variable speed spindle for it. PM-935 knee mill is made in Taiwan and would be even better if you can swing it. Both are 240V.
Enco has yearly 25% off sales that include machinery with free shipping. You could get a great deal on one of the knee mills if you sign up for their newsletter. I believe the Turn-Pro brand is Taiwanese.
Unread 15-04-2016, 10:22
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
I was going to be going back through the content of these threads looking for some recommendation for 4901's new machining equipment.
One thing I have to ask is there a good knee-mill that uses single phase power? There's no way my team can get a 220V+ hookup in our shop.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 15-04-2016, 10:53
FRC #2489
We have the same problem, we were originally looking at knee Mills, but we found we couldn't meet the 220V power requirements.
Unread 15-04-2016, 11:34
protoserge's Avatar
220-240V is typically single phase. 208-230V is typical three phase.
You can get static phase converters pretty cheap these days. If the motor is rated for inverter duty, you can get a variable frequency drive.
If you only have 120V available, there are VFDs for running three phase 208-230V motors, but you are limited in power.
A lot of knee mills are single phase, just check the motor nameplate.
Unread 15-04-2016, 11:42
We only have 120V availible.
John Fogarty
Unread 15-04-2016, 12:04
protoserge's Avatar
You might be able to get a 1-1.5HP 208 3 phase mill and run a properly rated 120V single phase to 208V three phase VFD. Your maximum current draw (I estimate 9-10A for a 1.5HP on 120V) may be closer to the limit of the common 15A 120V circuit than you'd like.
I believe most knee mills use standard frame motors, so getting a working solution (120V motor) may not be that big of a deal. If it came between making a knee mill work on 120V or getting a G0704, I would get the knee mill and live with the 0.5-1 HP compromise.
Unread 18-04-2016, 14:14
Tyson's Avatar
Tyson Tyson is offline
Rookie Year: 2011
Tyson is an unknown quantity at this point
Kent
Having a local distributor in orange county is a benefit I suppose.
http://www.kentusa.com/mills/
  #15   Spotlight this post!
Unread 18-04-2016, 16:51
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
New benchtop mill
Originally Posted by RoboChair View Post
This California bay area auction just went up.
http://www.westauction.com/auction/m...hine-shop-1474
If you PM me I might be willing to proxy for some of the more shippable items, inspect specific items, or pick up stuff if you are too far to drive. If you register to bid on anything please make your user name obvious that you are a robotics team (eg. FRC1678), don't want to get in bidding wars with other teams.
Just saw this auction. What are the worthwhile items for an FRC team? Does that Haas VF-1 have any use in FRC? That and the manual mill particularly perked my interest.
Edit: Here is the link for the Haas
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
