Go to Post Real world learning: teamwork, design, building, and testing. - Rob2713g [more]
Unread 16-04-2016, 01:58
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Rookie Year: 2013
Lireal is on a distinguished road
Step-up Converter for Mill
My team is starting for a mill for us to get for next year, and we were wondering if there was a way to use a standard houshold 120 volt, 20 amp circuit to power a 240 volt mill. Could we use something like these or would that cause problems?
Unread 16-04-2016, 02:01
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Step-up Converter for Mill
240 volt or 208 3-phase?
I believe some converters are sold specifically for the purpose of powering mills, both step-up and step-up + 3-phase converter.
What mill are you looking at?
<Now accepting CAD requests and commissions>
Unread 16-04-2016, 02:13
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (FTC# 11444 (Garnet Squadron)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
I believe the device that you need based on the other thread you started and the follow up conversation is called a VFD, Variable Frequency Drive. As to which one to get, that would be good to find out.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
"Head Bot Coach" FRC Team 4901 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1102, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 16-04-2016, 06:50
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
For the money spent on those transformers, you could just buy a 120V motor and switch it out. Some 240V mills can be wired for 120V, it depends on the motor. Post what mill you are considering purchasing and we can help you with options.
Unread 16-04-2016, 07:46
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
How many HP? You generally don't have enough power on 110 to run anything but the smaller machines and even then it is best to have it on a dedicated circuit.
If you don't know what you should hook up then you should read a data sheet
Unread 16-04-2016, 08:12
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Electrical delivery in homes is usually 220VAC.
They give you 2 sides of a transformer output.
Hence the 2 110VAC waveforms are out of sync.
Can you not get to the panel with 220VAC mains and get both hot wires?
If not the I agree with the others you should be mindful of not just the voltage but the power.
Unread 16-04-2016, 09:38
Tangert's Avatar
Tangert Tangert is offline
FRC #4467 (Titanium Titans)
Team Role: Coach
Rookie Year: 2013
Tangert is an unknown quantity at this point
The Step up Transformer that you are looking at is used to convert voltage from 120VAC to 240VAC its still is single phase or a polyphase not 3 phase. If possible you are better off going to your main panel and having an electrician run a new 240 VAC circuit similar to how your clothes dryer and your stove or run on. The reason for this is because when we Step Up voltage or amperage draw goes down while maintaining the same horsepower. Ohms law, Watts law. The more typical option recently for home machinist is to buy a variable frequency drive or vfd this will take single phase in and put out 3 phase in addition to that it very easily enables you to adjust the speed of your motor. You will need to look for one that has a single phase input in a 3-phase output that is also rated for the horsepower of your motor. Wolf automation has some affordable option (cheap) that work well on smaller projects. I prefer Allen bradlley products like the powerflex series. http://ab.rockwellautomation.com/Drives/Compact
Good luck. And be safe this is more deadly than 12VDC so make sure the work is being done by someone qualified.
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I've had one of this VFD on our lathe for years, and it works pretty well. However, you aren't really going to drive anything bigger than a 1HP or maybe 1.5HP 2-phase motor on a 120V 20A circuit and VFD.
