Go to Post I don't think it's that big of a deal if FIRST makes a few mistakes or cuts back every now and then. Personally, I'm just glad I have the opportunity to be in this program. - Crop-Circles [more]
Unread 01-08-2016, 18:11
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Best multi-tool for robot/field use
I'm seriously considering a multitool of some sort for FIRST and just general use. But there are so many different options here, so I'm wondering this: what tools are the best to have/most often needed for this purpose? I'm thinking it would be used for robot work and maybe field setup and teardown.
I think I want something that can cut zip ties; I know a knife can do it, but there's a high risk of damaging what the zip ties are near as well as injury. Do the Leatherman scissors work for this? Not sure if I need a saw, but for some reason I'm thinking I do, but most multitools only have wood saws. They would probably cut plastic/PVC, though. The Leatherman Super Tool 300 EOD has a metal saw, but cutting metal(or anything) sizable with a hand saw seems to take a while, though wood isn't too bad. But at the same time, I'm thinking I may not need it, as a hand or power saw can't be too far away at a FIRST event. I can see how a file would be useful, and needs for a screwdriver seem to arise often.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 02-08-2016, 02:54
Paul3161's Avatar
Paul3161 Paul3161 is offline
FRC #3161 (Tronic Titans)
Team Role: Leadership
Rookie Year: 2014
Paul3161 will become famous soon enoughPaul3161 will become famous soon enough
The tool I used was the leatherman wingman. The reason I liked it was because it had the things I needed and nothing more. It saved me time by not needing to flip through all the other useless tools that I did not need. The spring action needle nose pliers where extremely useful and made it even easier to fix our bot before the next match. Sad thing is I forgot it at the Mongolian grill after Waterloo :'( . Looking into getting a new one asap.
http://www.leatherman.com/wingman-11.html#start=2
Unread 20-04-2016, 07:27
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
Rookie Year: 2012
TogetherSword8 is an unknown quantity at this point
Originally Posted by Kevin Sevcik View Post
I used to carry a Paladin PT-540 until they stopped selling it and I foolishly snapped the pliers in half trying to twist something with them. It's a modified SOG multi-tool, so it's customizable. Mine was customized with a leatherman bit holder, V-cutter, and extra wire strippers.
Except for the part that my pliers aren't snapped in half, I am in agreement with this multitool. As an electrical person, I find myself using this when the proper tools can't be found (happens too much on our team, I don't know where 3 pairs of wire strippers can go to when only 3 people know how to properly use them), and for any last minute queue repairs.
The problem is that Paladin got bought by someone else (I forget who) and they are no longer manufactured, and you now would have to spend a good amount of money on eBay.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 20-04-2016, 09:36
scaryone's Avatar
scaryone scaryone is online now
FRC #0058 (The Riot Crew)
Team Role: Coach
Rookie Year: 2007
scaryone will become famous soon enough
Gerber Diesel. Bull nose version, replaceable with needle nose. Swap out jaws.
Unread 20-04-2016, 09:40
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Rookie Year: 2007
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
I wish leatherman made a multitool with a good side cutters on it for zip tie removal.
I have a wave that I typically carry with me, but I'm also looking for an update. The Leatherman MUT looks interesting as well.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 20-04-2016, 11:59
Foster Foster is online now
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Thats why I carry and use the Micra. Our teams all use the smaller ties, the Micra cuts them with ease. The next size up it will cut, but takes some effort.
The TSA collects these things on flights and they get resold. I picked up the last 5 for $7 each. I do that because roboteers sometimes walk away with them or forget to give them back. Clean them and they are good to go.
Once you carry the Micra you will be surprised at how much you use the scissors.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 20-04-2016, 12:01
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
My issue with the Micra is that I don't want to sacrifice my pliers or other tools (namely knives and real files) in order to gain the cutters.
Being correct doesn't mean you don't have to explain yourself.
Unread 20-04-2016, 13:24
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Agreed. The Micra that others suggested would only work for the light cable dressing ties. You'd struggle with the common medium and medium-heavy ties.
Foster, you might have my Micra, based on your source
scaryone, not sure what the Diesel gets me over my Super Tool.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 20-04-2016, 15:19
Arkive's Avatar
Arkive Arkive is offline
Kevin says "RTFM"
AKA: Alex Resnick
FRC #5109 (Gladiator Robotics)
Rookie Year: 2013
Arkive is a glorious beacon of lightArkive is a glorious beacon of lightArkive is a glorious beacon of lightArkive is a glorious beacon of lightArkive is a glorious beacon of light
Anyone know about the OHT from Leatherman? It looks like the spring action pliers would be really helpful when you have a part in one hard and have to quickly use a tool in another.
http://www.leatherman.com/oht-49.htm...sz=37&start=16
Unread 19-04-2016, 13:35
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight is an unknown quantity at this point
Foster- Your sizes seem like they are for very small fasteners
Hex Key 5/64" is for a #2 Cap head
Hex Key 3/32" is for a #4 Cap head
11/32 Nut Driver is for a #8 Nut
If your team has standardized on one or two fastener sizes it makes it easier to carry less items, but the correct specialized tools for the job rather than a multi-tool.
Klein 68236 Fully Ratcheting and offset 3/8 & 7/16 Box wrench - Exact fit for Size 10 & 1/4 fasteners locking nuts that we have standardized on.
Klein or other Hex Key Folding Set - Make sure it has 7/64, 9/64, 5/32 and 3/16 to cover all standard cap heads #6-1/4 in size.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 19-04-2016, 14:37
Yep, I split my time beween VEX and VEXIQ. All the fasteners in VEX are either 6/32 or 8/32 cap or socket heads screws and #8 nuts. So my world is lots simpler. Sadly they don't make multi-tools with that in mind. (Looking to do a Kickstarter? Over 10,000 VEX teams to sell to!)
When I was doing FRC full time we tossed all the screws that were not cap head ( multiple sizes of Phillips head, torx, -, Robeson, etc). OEM stuff that came with other than cap heads got reassembled with caps. It really cut down on the number of different tools needed.
Standardization of fasteners is an amazing thing. But I think that's another thread too.
Unread 20-04-2016, 01:46
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
My Leatherman Wingman has been a life saver. Came in handy every competition. That said I am buying the OHT at the facore store right before CMP because, 1) fast draw pliars 2) I camp a lot and I need the saw and 3) it has everything in want and nothing I don't.
After using the Wingman I can not imaging ever using a Leatherman without spring loaded pliars.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 20-04-2016, 02:10
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
While just barely a multi-tool I really like my Gerber Curve mainly because the knife is small enough that it doesn't look weird carrying it in a school environment. It's also cheap enough that I don't mind abusing the blade. The flat head screwdrivers are also perfect for pushing down Weidmuller connectors and ground sharply for prying.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
Unread 20-04-2016, 10:44
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
If you are looking for a Leathermam with scissors/cutters, take a look at the Micra. It is a small tool, but still has a nice feature set. The main tool on it is a fairly good set of spring loaded scissors. It looks like that might be what you need.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
  #15   Spotlight this post!
Unread 20-04-2016, 11:51
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Literally my only complaint with the Wave, as well.
