Go to Post Understand that not only can you learn from other experienced engineers, but also mechanics, farmers, and craftsmen. - Andy Baker [more]
Unread 07-08-2016, 15:38
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Best multi-tool for robot/field use
I haven't limited my search to just Leatherman, but they seem to have the best selection of tools for robot/electronic/mechanical use. I think the Surge might be best, as it has the most tools. I've seen others recommend the Crunch and the Skeletool; while the Crunch does look useful, I'm not sure it's worth sacrificing other tools for locking pliers, though at the same time, I'm thinking "less is more". I'm also considering the Leatherman Piranha 2 or the Gerber Shard for my keychain. I like that the Piranha has wrenches, but its reviews are mixed. Anyone used a Swisscard or a Wallet Ninja? The Swisscard seems good, but it's plastic and I worry about it breaking in my wallet...the original Ninja seems unavailable, though with its wrenches I may not need the Piranha.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 08-08-2016, 08:06
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
Rookie Year: 2012
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
You and your multitools.
Boxcutter, small sidecutters, and a jewler's screwdriver, and sometimes I'd run with a pair of robogrips and allen set. Separate items which work better than multi-tool equivalents, and don't break down. "Where do you hold all that?" Carpenter jeans, doi
Can't get a leatherman in tight spaces like a jewler's screwdriver, can't cut as well as a boxcutter, and you can't snip zipties worth a $@#$@#$@#$@# with a leatherman. Leathermans also don't tend to work very well for holding onto hex heads... or any bolt heads... and don't have allen heads...
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://ppi.ddns.net/blog
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
