Go to Post Remember there are many eyes watching and often you are judged by what you say and how you say it. - Mike Martus [more]
Unread 19-04-2016, 21:09
Austin.Loach Austin.Loach is offline
Austin.Loach is an unknown quantity at this point
Smile How do I hook up the motors to the wheels?
I know this might sound very basic, but I'm quite new to robotics and I'm trying to build a project robot with my father. I know what I need to get the motor turning, but my question is just how do I connect the wheels to the motor? I've heard you HAVE to you use a gearbox but others have said there are other ways than just that... Any help would be appreciated. Thanks in advance!
Unread 19-04-2016, 21:11
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Rookie Year: 2013
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: How do I hook up the motors to the wheels?
Can you post a picture of what motors you are using? It usually depends on the motor's output (drive) shaft.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Rookie Year: 2012
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
We can help you more if you tell us what motor and what wheel you want connected.
Generally motors run at speeds that are too fast for a wheel to do something useful (unless you want to shoot a ball or something) which is why a gearbox is often used.
Generally if you want to drive a wheel off a motor you would use a hub that matches the shaft on your motor and bolt it onto the wheel. But this depends on the motor and wheel combo, so more details are needed.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 19-04-2016, 21:13
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
It depends on the motor and wheel that you want to match up, and what the purpose of the wheel is.
For example, in some cases you could press the wheel onto the axle of the motor. You could use a hub to do the same thing. But, in those cases you want the wheel to spin as fast as the motor does, and for the vast majority of motor/wheel setups that isn't the case. So, you'll need some sort of gear reduction. That could be a chain or belt setup with different sizes of sprockets or pulleys, respectively, or it could be a gearbox.
The big trick is that it's entirely dependent on the motor, the wheel, and the application. What works well for, say, a shooter wheel might not work so great if you're trying to use it in a drivetrain (read: might not work at all).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 19-04-2016, 21:28
Alright, well I haven't actually purchased any motors or wheels or anything of the sort just because I didn't want to waste money on some parts then have them not go together..
I was thinking of using these wheels
http://www.andymark.com/product-p/am...k.htm?CartID=3
and using these motors
http://www.andymark.com/Motor-p/am-0255.htm
But again, I'm rather new and don't know to what extent those will work together (if at all). So if these don't go together, could you just suggest a cheap(ish) alternative to what I have chosen? Thanks again everybody!
Unread 19-04-2016, 21:33
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
http://www.andymark.com/product-p/am-0588.htm
Now, what did you say your application was again? We can't tell you if that's a good idea or not without knowing a little bit about what you're trying. By the way, your free speed would be about 95 ft/second if my math is right and you're driving with that thing (RPM of motor at 5500, C=pi*4" diameter, and 1 revolution moves you 1*C). Depending on loaded speed, you'll stall pretty quickly, though. (Again, if you're driving. If you're trying to shoot something, you might need to go the other way and spin faster.)
Past teams:
Unread 19-04-2016, 21:34
Sorry! Some wheels will be for driving some for moving an arm-like body part.
Unread 19-04-2016, 21:37
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
If this is for a non-FRC project, then you don't need to adhere to typical allowed motors.
Cost is obviously important for you, I would suggest looking at the gearboxes and motors sold by BaneBots, their gearboxes and motors are on sale at the moment, same with their wheels.
http://www.banebots.com/category/P60_7.html
The motors you select are dependent on the weight and size of your robot.
But a 550 or 775 motor should easily be fine, for a driving a decently sized robot
http://www.banebots.com/product/M5-RS550-12.html
http://www.banebots.com/product/M7-RS775-18.html
For wheels have a look at these http://www.banebots.com/category/COLSON_WHEELS.html and these
http://www.banebots.com/category/COLSON_HUBS.html
With a robots project, the motor controllers are going to be a big cost component and would probably be about $45 if you went for the low cost REV Spark
Sponsors, parents, students and mentors love helping teams succeed. Denso Throttle motors also want to help, don't break their hearts. REDBOX(gearbox for the throttle motor)
Facebook
Unread 19-04-2016, 21:39
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Way too fast. As I noted in my edit, your theoretical top speed is 95 ft/second on driving, and you really don't want to know how hard you'll hit with an arm in motion...
I think you need the JVN Calculator (might be a hair out of date, but it'll have the CIM in there).
Past teams:
Unread 19-04-2016, 21:49
pilleya's Avatar
Elec+Mech
Rookie Year: 2013
Yep the JVN calculator is what you want, it'll help you work out what motors and what gearing to use to drive your robot and also the motor and gearing required to move the robot arm.
JVN released an updated calculator for 2016: http://www.chiefdelphi.com/media/papers/3188, but the most likely won't make a difference for this purpose
Facebook
Unread 20-04-2016, 10:35
Alright everybody I've figured it out with the gearboxes and motors.
For the drivetrain I'm going to use
http://www.andymark.com/Motor-p/am-0912.htm?CartID=8
this motor and
http://www.andymark.com/product-p/am-3105.htm?CartID=7
this gearbox.
For an "arm-like" function I'm going to use
http://www.andymark.com/Motor-p/am-0255.htm?CartID=10
this motor and
http://www.andymark.com/product-p/am-3106.htm?CartID=9
this gearbox.
Thanks for all the help!
Unread 20-04-2016, 10:47
Billfred's Avatar
Billfred Billfred is offline
this motor and
this gearbox.
this motor and
this gearbox.
I think you've got a scale issue. The 9015 motor is about the size of a prescription bottle, while the CIM is about the size of a Coke can. Neither was made with the Neverest gearboxes in mind, and I'd be shocked if a Neverest gearbox could withstand what a CIM puts out for any length of time. (We use 2-6 of those to drive 150-pound robots.)
What size of robot are you looking to build, either in dimensions or weight? What, if anything, does the arm have to lift? That will help us get you in the right direction.
Unread 20-04-2016, 10:56
The whole robot is going to be about 3 feet tall and a foot and a half wide and long. The whole thing made of aluminum (idk how much that would weigh). And the arm would have to move nothing but itself. I will have 4 motors for the drivetrain and one for each arm.
Unread 20-04-2016, 11:24
Matt_Boehm_329 Matt_Boehm_329 is offline
FRC #0329
Team Role: Tactician
Matt_Boehm_329 has a spectacular aura aboutMatt_Boehm_329 has a spectacular aura about
If you upload a sketch of what you are looking to do we may be able to better help you
  #15   Spotlight this post!
Unread 20-04-2016, 12:12
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
I don't think you should spend money on motors until you've done the calculations for what you actually need.
Since you haven't given any requirements, we can only help you find components that are compatible with each other.
