Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 20-04-2016, 16:53
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Cheapish CNC machine
Does there exist a cnc machine under 2000 dollars that has a reasonable working bed.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 20-04-2016, 16:58
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
Re: Cheapish CNC machine
Do you have any machining companies nearby? Sometimes it is less expensive for a company to donate an old CNC to a FRC team than it is to dispose of it. FIKE Corporation in Kansas City did just that for us between the 2011 and 2012 seasons.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 20-04-2016, 17:07
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
Rookie Year: 2010
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
I don't have one, but I've watched Taig CNC mills on ebay for years. New they're a little more than your budget ($2500), but used they're sometimes pretty low priced.
They're really small, essentially a jewelry mill, but most stuff on a robot isn't so big.
You'll need the right computer to go with and software and tooling, but I'd consider this.
You can also buy the mill with manual cranks then upgrade to CNC later, to spread the budget out.
http://www.taigtools.com/cmill.html
http://www.ebay.com/sch/i.html?_from...+mill&_sacat=0
Unread 20-04-2016, 17:10
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Absolutely:
You did not say that does not read punch tape or punch cards
My MaxNC 10 was < $2,000 used with software and some tools.
My MaxNC 15 was < $2,000 used with software and some tools.
My MaxNC T2 was < $2,000 used with software and some tools.
My CNC retrofitted Sieg X2 with Freak mods from Hoss was < $2,000 with no tools at all.
My manual ShopMaster 2000 with CNC plates ready to be populated was < $2,000 in 2004 with a box of rusty tooling.
If you watch long enough you'll no doubt find a Bridgeport or clone that has a retrofit but again you might find yourself with a 19" computer rack and it may read punch tapes or punch cards.
To put this simply: G-code is older than you high school kids.
If you can find some used X/Y/Z tables with steppers you make a CNC very easily.
Unread 20-04-2016, 17:24
Montavo Montavo is offline
AKA: Eric Montano
FRC #0841 (The BioMechs)
Rookie Year: 2012
Montavo is on a distinguished road
For less than $2,000 you can purchase a fully loaded CNC Router, X-Carve by INVENTABLES. It comes with the basic tools to get going on machining, what some might see as a down side is that you have to assemble and wire it yourself.
Other than that it seems like fine router for the budget.
subtotal:$1,399.90
shipping cost: $228.61
Grand Total: $1,628.51
Edit: Build Area is 1000m x 1000m | 39.4" x 39.4"
Unread 20-04-2016, 18:33
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Do you have any personal experience with the x-carve?
Unread 20-04-2016, 18:39
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I love my X-Carve. It's real good with wood and polycarb but not real good for aluminum.
Unread 20-04-2016, 18:40
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
the x-carve website says it can handle alminum just as well... what's wrong with it?
Unread 20-04-2016, 18:49
DonRotolo's Avatar
Back to humble
FRC #0832
"handle aluminum" is relative. To put it simply, it is not a mill.
Using a light-duty router to cut aluminum is similar to using a small hammer to break up a sidewalk: It'll work, Be careful to take it easy and you won't damage the hammer, but it'll take a long time.
Unread 20-04-2016, 19:02
IndySam's Avatar
Exactly, engraving AI is OK but any serious work requires slow feed rates, shallow cuts and lots of oil. It takes a couple hours for even a small bracket.
Unread 20-04-2016, 19:24
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
subtotal:$1,399.90
Note, a default X-carve has trouble milling aluminum. Really nice for wood and plastic though.
*RIP others said it first
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 20-04-2016, 19:26
techhelpbb's Avatar
Rookie Year: 1997
Cheap CNC milling/engraving machines tend towards open loop steppers.
Steppers deliver maximum torque near the lowest RPM.
If you go too fast you miss a step and then your computer can not see that and everything gets offset till you ruin the work.
Mind you 3D printers and plasma tables use these same motors but the forces acting against movement are magnitudes less.
MaxNC put encoders on their closed loop axis steppers.
If they miss a step they try 8 times then give up and stop.
Servos with DC brush motors are available but add to the machine cost quickly.
IMSRV makes a Globe motor reduction to bolt on in place of a NEMA23 stepper.
At the cost of a new control and a few hundred an axis.
Really good machines use brushless AC motors for the servos.
Rigidity comes into play. As you push tools into the aluminum it 'pushes back'. A frame rigid enough for wood or plastic may not be rigid enough to push into aluminum without deflecting making the cuts worse or breaking tools.
Even my MaxNC uses a Taig spindle. That spindle is turned by a Baldor Universal AC/DC motor and maxes out at 3,000RPM. There is a single stage reduction. I could go faster but my steppers can not provide the force to move to match the spindle speed.
If you must run a high speed palm router for wood you can get a SuperPID that will slow it down so you do not rub the cutter. However you give up some HP in the trade. Good spindles are closed loop and will hold RPM even under cutting load.
By the time you optimize that X-Carve you are over $2,000.
Someday I want to take FRC parts and make a router suitable to build FRC robots.
Probably have to float a battery to handle the low voltage CIMs but it could be done.
Unread 20-04-2016, 20:29
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
I built this machine for about 500$ USD (I haven't built the enclosure yet so it's a bit of mess). It cuts aluminium better than X-Carve or Shapeoko IMO, I can fairly easily do 1/16 DOC at 15 IPM with a 1/8 Carbide single flute end mill. I cut this sprocket on it in about 15 minutes. It's definitely not something I'd recommend to someone new to CNC machining but a practical machine for aluminium can be made for well under the price of an X-Carve.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Ref, Inspector
Unread 20-04-2016, 20:35
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
That looks really good! Any chance we can get some plans?
I've seen Shapeoko 3's out-of-the-box cut aluminum, albeit slowly.
<Now accepting CAD requests and commissions>
  #15   Spotlight this post!
Unread 20-04-2016, 20:37
pmangels17's Avatar
pmangels17 pmangels17 is online now
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Could you share a bit more about how you made this machine. That is gorgeous and the price is a gamechanger.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
