Go to Post You people are online way too early in the morning... - Beth Sweet [more]
Unread 20-04-2016, 21:29
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
MVPWM-101, cheap servo tester
Lately I've been working on a cheaper alternative to the Pulsinator and Thrifty Throttle, because I am so cheap that I don't want to spend $30 on testing mechanisms.
So I've created MVPWM-101, a $5 servo PWM generator that can be powered through USB port, plugged into a Talon SRX, or take any 5v input voltage.
Picture is attached.
I did screw up slightly on the potentiometer boundaries, which is why it sits partially on top of the USB port. MVPWM-102 will feature a micro-usb port to let users power it from laptops or external phone battery packs.
I'll also be releasing a through-hole component version that should only be slightly more expensive, but let any team with a soldering iron make one.
Here's a video of it controlling a servo (analogous to controlling a Talon or Victor): https://youtu.be/HDhfyetcpek
<Now accepting CAD requests and commissions>
