Go to Post Sleep... what is this sleep you speak of? - Choi9111 [more]
Unread 21-04-2016, 16:33
Abhishek R Abhishek R is offline
Rookie Year: 2012
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Re: Blocking 2 ball autons
Well, it's possible that you start with no ball, grab the ball the two-baller intends to take, then score that ball by crossing over the nearest defense and shooting. The risk you run in that case is "are you fast enough to grab the ball before the other team does?" Because if you don't get the ball, you won't score any balls in auto.
Furthermore, the teams most likely capable of this are probably doing their own two-ball or a one-ball over a tougher defense than the low bar, so their priorities may be elsewhere.
IMO the risk and comparative resources of the alliance necessary to pull this off will not make it worthwhile and we'll see more teams just focus on having all three of their robots drive over the defenses and score a ball. That doesn't mean it won't happen at all, I just don't see it being as big of a focal point as the can races last year.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 21-04-2016, 17:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Oh man, not this again. At least it's optional this time and not as likely to end with two robots semi-permanently attached...
Seriously, though, it seems like everyone is dropping a ball off by the wall. Instead of a drag race, it seems like you would be better off outtaking your own ball at the dropped ball to disrupt its position and cause a hiccup that way.
I actually think this is the only viable option, since it's really unlikely you can successfully start between the midline and your opponent's secret passage. Here's what the auto would look like:
Setup: In front of defense 1 lined up to intake ball 2 (one down the line from the one you opponent's intaking).
1.Rotate to face your opponent's dropped ball, outtake at high speed.
2.Rotate straight, intake mid-line ball.
3.Cross defense in front of you.
4.Score ball in auto.
Super simplified, of course. You can skip 2 and 4 if you're already not scoring a ball in auto, though. I think it'd be doable, the question is whether you can hit the dropped ball accurately enough and hard enough to disrupt things. And whether you'll get a foul for using a boulder to make a defense harder if one or both carom into the low-bar and jam things up there.
Unread 21-04-2016, 17:51
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Originally Posted by jspatz1 View Post
"G13 During AUTO, ROBOTS may not enter the volume above the MIDLINE.
Violation: FOUL. If contact is made with an opponent ROBOT beyond the MIDLINE (either direct
contact or transitive contact through a BOULDER), an additional FOUL is assessed and the
opponent ROBOT is immediately awarded the CROSSING of the closest DEFENSE from the point
of contact."
In my interpretation, transitive means direct contact. Once I release a boulder from my robot I can no longer be in transitive contact with an opposing robot through that boulder. I do not think that an opposing robot will get to the mid-line ball faster than the ball reversed out of the defensive robot will. Transitive is not defined in the game manual glossary, so it is open to interpretation.
This is more along the lines of what I think would work, but for a mid-line block rather than finding the opposing dropped ball. There is no rule that a robot start with bumpers parallel to the field walls, a robot could start angled so that it can immediately release its intake ball to knock the mid-line ball off course. Then it can either cross or (in your more daring method) attempt to intake a mid-line ball itself before crossing. I think the strategy only really makes sense if your robot has little to no chance of scoring a high goal in autonomous (low goal only bot, defense bot with less shooting capability), in which case the extra mid-line ball after defending the 2 Ball auto is a pretty low benefit for the effort involved.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 21-04-2016, 18:58
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
That sounds like a G39 violation to me.
However, I should make it clear that I'm not a ref, so I don't even have the right to comment.
Unread 21-04-2016, 19:13
apm4242 apm4242 is offline
FRC #4242
apm4242 will become famous soon enoughapm4242 will become famous soon enough
Yeah, this may be a dumb question, but how do all 2-ball autos not violate G39?
G39 ROBOTS are prohibited from launching BOULDERS unless they are in contact with the opponent’s TOWER or carpet in the opponent’s COURTYARD, and not in contact with any other carpet.
Isn't launching defined as intentionally imparting any momentum to the ball? Therefore, wouldn't intentionally dropping the 2nd ball be launching?
Similarly, how does the 2-ball auto defense by launching a boulder to disrupt the pickup not violate G-39?
EDIT: This was all I could find on Q&A:
Q533
Q. Can you further clarify the definition of "launching" as it applies to G39? Would either of these actions be considered a G39 violation if performed while in contact with the Neutral Zone or a team's own Courtyard: A. A robot very weakly ejects a BOULDER through an upward-facing mechanism normally used for shooting, such that it rises a minimal height required to clear the mechanism and then drops to the ground. B. A robot forcibly ejects a ball at ground level, rolling it across the field.
A. Good question. Releasing a BOULDER such that it is not shot in the air, but dropped from a certain height is not launching. A ROBOT that "forcibly ejects a ball at ground level" would be considered "launching," and this will be clarified in Team Update 03.
Although, I still think it's vague
Unread 21-04-2016, 20:37
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
I think it is very unlikely for an "arms race" of speed to the first ball to become a thing. Firstly, there are only a handful of robots, out of hundreds at CMP, that have demonstrated the 2-ball auto. The odds of meeting one in a match and being prepared to reach this ball faster than them (< 0.5 seconds?) in a match where they decide attempt it is extremely small. Can burglars in 2015 were much, much more common.
Secondly, the space available between this first ball and the berm on the defensive side is very narrow. Most robots would not fit in this space facing the ball. We once tried to place a dead partner in this space, and could not fit them there even sideways. Any movement required by the defensive bot is unlikely to win a race to the ball, the 2-baller has a significant set-up advantage.
Unread 21-04-2016, 20:44
Starting the match partially inside of the secret passage is perfectly legal.
Unread 21-04-2016, 21:05
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
I only meant that this area is not clear and is obstructed by the berm.
Unread 21-04-2016, 21:09
The Arizona Mentor
AKA: Andrew
Originally Posted by apm4242 View Post
Q533
Well scratch my idea off the list. Under this strict interpretation any reversing of an intake with decent speed while in the Neutral Zone should be called as a launching violation. This was not something we were watching for when I was reffing and I would not have called a penalty for that without having this Q&A brought up.
Unread 21-04-2016, 21:10
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
Rookie Year: 2012
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
Actually, based on the information you currently have, not a dumb question at all. my guess would be that the refs are only considering it "launching" if you're trying to score a boulder in a goal. otherwise, teams potentially wouldn't be able to do two rather important things:
1. eject boulders that are improperly loaded into their machines
2. eject a second boulder if they accidentally pick up 2 of them
without being subject to a G39
now as for how this relates to autonomously blocking their autos, I see this as very grey area. there's certainly nothing outright prohibiting it, but there's nothing that out rightly allows it either
personally, I think they should allow it. I'd like to see these battles happen
(I don't have any official weight behind what I say here, just how I think it's being/should be interpreted)
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 22-04-2016, 07:50
FRC #4242
I agree. Anyone else think it's odd that dropping a boulder and having it hit your bumper which causes it to roll across the floor is ok but rolling a boulder across the floor is not?
I'm definitely not against 2-ball autos - they're undeniably awesome and should be allowed. It just seems like this Q&A response is written to specifically allow them...
Anyway, just a thought.
Unread 21-04-2016, 16:37
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
Rookie Year: 2013
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
of contact."
Is it still a foul if neither of the robots enter the volume of the midline? It looks to me that this rule states you get a double foul if you make transitive contact and are violating G13 by crossing the midline.
If I'm wrong, then I guess the foul would apply to whoever reaches the boulder second. In that case, the defending robot just needs to be confident that they're faster.
Edit: Actually, I might be misunderstanding what "transitive contact" means... I figured it means that if two robots are contacting the same ball, then they are effectively contacting each other
Head Programmer / Driver
Unread 21-04-2016, 16:40
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Rookie Year: 2012
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
of contact."
The ball has half of it's volume on each side of the midline. This means you do not need to cross it to move it out of position. If the first thing you do in the autonomous mode is simply nudge the boulder, you run very little risk of making transitive contact through a boulder since you will not be touching the boulder by the time the second robot makes a grab for it.
In addition, if you make first contact with the boulder it would be the other team incurring the foul for contact, not you. If your robot is touching a boulder and the 2-ball auto team tries to intake it, they would be making transitive contact through a boulder with you, not the other way around (you are not making transitive contact if you get there first).
In a way I could see this becoming a new kind of canburglar arms race, where teams try to touch the boulder first. From the way the rules appear to be written it seems that if you touch the boulder before the 2-ball auto bot tries to intake it, they're making contact with you and they will be fouled. If they make contact first, then you nudging it will be considered a foul. Thus, the speed at which you can get to that essential (for a 2-ball auto) boulder will become more important as the stakes get higher.
It's not done until it's overdone!
Unread 21-04-2016, 16:44
Littlepchan's Avatar
Littlepchan Littlepchan is offline
Maker. Innovator. World Changer.
FRC #5431 (Titan Robotics)
Team Role: Leadership
Rookie Year: 2015
Littlepchan is an unknown quantity at this point
Assuming one of the two balls is taken, we would have to look at the next step and whatever defense is in position 1. If the defense in position 1 something that can be easily crossed like the rough terrain then a team could supposedly cross and shoot (best case scenario). Worst case scenario, the opposing team gets 5 extra points and another life point off a defense.
  #15   Spotlight this post!
Unread 21-04-2016, 16:06
Bob Steele's Avatar
Bob Steele Bob Steele is online now
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
In order to block the 2 ball auto, a team would have to give up on their own 1 ball auto in my opinion. Either grabbing the ball or intentionally hitting it would constitute possession.
If the only purpose in doing this is stopping the 2 ball auto... it would be a net gain of 0.
If a team could do this and still score a ball then it could be a net gain. This would mean you drop your ball... move to hit a ball or pick it up and then use it.
If you could stop a 2 ball and then do a 2 ball it would be amazing.
Unfortunately the only 2 ball autos that have been consistently shown are low bar versions. (Please correct me if I am wrong) So stopping a low bar 2 ball would have to come from a position on the field that can't easily do the two ball.
I am sure that some teams are working on fantastic auto routines and I look forward to seeing them in St. Louis. I also think that doing an anti-two ball auto is something that won't really help your team very much and that trying to do your own two ball auto is a better use of time. (Or solidifying a perfect 1 ball auto....)
IMHO
Feel free to disagree ....
Good luck on the field
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
