Go to Post Though, of course, if the old one you like is shot, then you can just beat your new one with a hammer until it works the way you want. - Kevin Sevcik [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 22-04-2016, 15:29
wjordan wjordan is offline
FRC Stathead
AKA: Wes Jordan
FRC #2363 (Triple Helix)
Rookie Year: 2013
wjordan is a jewel in the roughwjordan is a jewel in the roughwjordan is a jewel in the roughwjordan is a jewel in the rough
2016 Pre-Champs ELO Ratings
I wrote a small Python script (similar to this thread from 2014) to calculate the season-long Elo ratings for all 3000+ plus FRC teams that competed in the 2016 season. Here's the top 100 (keep in mind this a fairly untuned model):
Code:
Rank,Team,Elo Rating,# Played,Win %
1,frc2056,2564.8708516684,32,0.84375
2,frc987,2556.7395845976,31,0.8709677419
3,frc148,2513.3702482568,32,0.8125
4,frc2771,2509.4705400282,48,0.75
5,frc1241,2437.9107936136,35,0.8571428571
6,frc1519,2435.0658342396,36,0.9444444444
7,frc133,2432.4950118635,36,0.8888888889
8,frc118,2410.6631929387,28,0.8571428571
9,frc27,2408.0850729022,45,0.8
10,frc359,2393.7669444743,32,0.90625
11,frc1678,2365.1427556916,26,0.8846153846
12,frc1983,2352.9683563234,48,0.7708333333
13,frc1023,2327.1563415467,46,0.8260869565
14,frc1501,2314.8914797357,48,0.7916666667
15,frc1540,2308.9583510968,36,0.8333333333
16,frc4564,2299.9814293025,36,0.8611111111
17,frc225,2286.8436656747,36,0.9166666667
18,frc319,2267.1466845432,48,0.7291666667
19,frc2046,2262.0104039536,48,0.7291666667
20,frc3620,2258.2489588419,36,0.8055555556
21,frc2767,2231.1523749957,36,0.8888888889
22,frc125,2203.9042618114,58,0.6724137931
23,frc217,2193.7623220698,45,0.7111111111
24,frc67,2193.5383205599,36,0.8611111111
25,frc254,2190.187307243,19,0.9473684211
26,frc195,2174.4289095983,36,0.8055555556
27,frc179,2164.4363863313,27,0.9259259259
28,frc2013,2162.9140605587,33,0.7272727273
29,frc33,2155.8558874617,36,0.7777777778
30,frc971,2150.359414525,16,0.9375
31,frc4188,2147.4291381874,46,0.7608695652
32,frc910,2143.8934792287,33,0.7878787879
33,frc2590,2142.9579313632,45,0.6888888889
34,frc25,2142.4412456836,36,0.8055555556
35,frc4450,2139.5744792782,36,0.8055555556
36,frc4967,2138.8294065088,36,0.7222222222
37,frc2468,2133.6054741145,32,0.78125
38,frc1024,2132.5886298519,48,0.7083333333
39,frc2974,2126.6132833861,36,0.8055555556
40,frc1746,2122.4741745816,36,0.8611111111
41,frc1986,2105.5705944366,20,0.95
42,frc4334,2090.8271976938,23,0.8695652174
43,frc1261,2087.3494490483,48,0.7083333333
44,frc3314,2076.4327449113,57,0.701754386
45,frc4488,2076.2542185479,36,0.7222222222
46,frc1533,2072.1356193236,48,0.6458333333
47,frc3230,2071.4881103811,35,0.7142857143
48,frc2481,2068.7886898013,21,0.9523809524
49,frc494,2065.1162537725,36,0.8055555556
50,frc869,2062.6485747098,48,0.6875
51,frc230,2061.1864101023,48,0.6458333333
52,frc5279,2060.1866212576,36,0.7777777778
53,frc238,2057.8208919517,48,0.6875
54,frc5172,2055.2630353144,18,0.8888888889
55,frc2067,2054.8484971032,48,0.6875
56,frc1318,2048.8236076466,48,0.7291666667
57,frc3250,2036.8233126059,30,0.7333333333
58,frc5050,2034.4232765669,36,0.7777777778
59,frc4469,2033.0203537629,36,0.8055555556
60,frc3310,2031.833668903,20,0.95
61,frc1058,2029.9012706186,48,0.6458333333
62,frc330,2023.303386855,20,0.85
63,frc4468,2020.8796496031,36,0.7777777778
64,frc365,2015.2776518452,36,0.75
65,frc868,2013.0139180101,46,0.7173913043
66,frc1418,2004.4858845658,34,0.7352941176
67,frc2415,2002.7041652616,36,0.6944444444
68,frc16,2001.6149194784,19,0.8947368421
69,frc3688,2000.4276164977,36,0.7222222222
70,frc3990,1993.4366845031,21,0.9047619048
71,frc1747,1989.0741465466,48,0.6875
72,frc3357,1987.188575724,48,0.6875
73,frc368,1982.42880364,20,0.95
74,frc5460,1981.5616311026,36,0.6944444444
75,frc3238,1976.6527065089,36,0.7777777778
76,frc525,1976.440984525,18,0.8888888889
77,frc4384,1973.7651648588,36,0.5833333333
78,frc836,1972.003555699,34,0.7352941176
79,frc71,1970.1239091472,36,0.6944444444
80,frc56,1969.5271280769,36,0.6944444444
81,frc1731,1966.9417414622,36,0.75
82,frc1305,1964.9589066452,31,0.7096774194
83,frc1918,1961.9294395633,36,0.75
84,frc3604,1960.9763143508,36,0.7777777778
85,frc41,1959.5598450238,36,0.5833333333
86,frc2474,1957.2471714871,36,0.6666666667
87,frc4063,1956.7118381526,29,0.724137931
88,frc1425,1953.6830324716,36,0.75
89,frc1806,1951.7294052903,19,0.8947368421
90,frc2471,1950.9437092534,36,0.7222222222
91,frc3683,1947.6203673269,23,0.7826086957
92,frc1114,1944.3669483275,23,0.7826086957
93,frc5895,1941.0093857167,36,0.7222222222
94,frc3618,1941.0017737099,48,0.7083333333
95,frc3309,1934.657254773,32,0.6875
96,frc107,1931.3958797577,36,0.6944444444
97,frc1124,1921.5875314542,48,0.6666666667
98,frc4103,1919.8324175315,36,0.6944444444
99,frc3021,1917.1307148459,21,0.8571428571
100,frc85,1914.7890005898,36,0.7222222222
Full ratings can be found here: http://wesj.org/documents/elos_2016.csv
Methodology: I initialized all teams at the beginning of the season at 1500, and had ratings persist between competitions. The only matches considered by the model were qualification matches at official events. I decided to discount playoff matches because I wanted the ratings to reflect the best robots at an event, not necessarily the best alliances. Adding elimination matches massively inflated the ratings of 2nd picks on very strong alliances, often making them the third-highest rated robot at an event despite that usually not being the case. (I can post ratings with eliminations if people really want them, however)
I also used a margin of victory multiplier similar to the one used for FiveThirtyEight's NBA Elo Ratings, which rewards underdogs for upsetting higher alliances, but for stronger alliances only rewards a little for beating weaker alliances. Most of the tuning values I used for these rankings were taken from the 538 values for the NBA, largely due to the rough similarity in scores between the NBA and Stronghold.
Here's the script I used. I added parameters for the k-values, as well as the margin of victory multiplier function, and match level. (The 'tba.event_get()' method is taken from the the TBA wrapper script I use, and essentially just gets the event matches and teams from the TBA API and parses them into a dict using json.loads()).
Code:
def elos(event_key, k=20, mov=lambda elodiff, scorediff:  ((scorediff + 3) ** 0.8) / (7.5 + 0.006 * (elodiff)), level='qm'):
    event = tba.event_get(event_key)
    elos = {}
    for team in event.teams:
        elos[team['key']] = 1500
        played[team['key']] = 0
    for match in event.matches:
        if level is not None and match['comp_level'] != level: continue
        red = match['alliances']['red']
        blue = match['alliances']['blue']
        red_elo = statistics.mean(elos[team] for team in red['teams'])
        blue_elo = statistics.mean(elos[team] for team in blue['teams'])
        expected_score_red = 1. / (1 + 10 ** ((red_elo - blue_elo)/400.0))
        expected_score_blue = 1. / (1 + 10 ** ((blue_elo - red_elo) / 400.0))
        score_break = match['score_breakdown']
        red_score = red['score']
        blue_score = blue['score']
        actual_score = 0.0
        margin_mult = 1.0
        if red_score > blue_score:
            actual_score = 1.0
            margin_mult = mov(red_elo-blue_elo, red_score-blue_score)
            #margin_mult = ((red_score - blue_score + 3) ** 0.8) / (7.5 + 0.006 * (red_elo - blue_elo))
        elif red_score == blue_score:
            actual_score = 0.5
            #margin_mult = (3 ** 0.8) / (7.5 + 0.006 * (red_elo - blue_elo))
            margin_mult = mov(0, 0)
        else:
            actual_score = 0.0
            margin_mult = ((blue_score - red_score + 3) ** 0.8) / (7.5 + 0.006 * (blue_elo - red_elo))
            margin_mult = mov(blue_elo - red_elo, blue_score - red_score)
        for team in red['teams']:
            elos[team] += k * margin_mult * (actual_score - expected_score_red)
            played[team] += 1
        for team in blue['teams']:
            elos[team] += k * margin_mult * (1-actual_score - expected_score_blue)
            played[team] += 1
    return elos
Please let me know if you have any suggestions or questions about these ratings.
2016: Northern Virginia Winners (1418, 2421), Hampton Roads Finalists (1885, 5954)
2015: Virginia Winners (384, 1610), Chesapeake Winners (1690, 4050)
2014: Chesapeake Winners (1629, 623), Galileo Winners (67, 973, 2481)
2013: Virginia Finalists (2053, 3015)
[IMG] code is Off
