Go to Post I am a mechanical engineer. I have known since I was about 12 that I wanted to make complicated mechanisms. - Paul Copioli [more]
Unread 24-04-2016, 09:46
PAYA PAYA is offline
PAYA is an unknown quantity at this point
GT2 PROFILE 3-D CAD FILE FROM SDP/SI.
I TAKE ONE 3-D MODEL OF PULLEY WITH GT2 PROFILE FROM SDP/SI WEB PAGE ,AFTER OPEN FILE AND CHECKED I SAW NOT CONFORMITY WITH GT2 PATENT AND VERY DIFFERENT BETWEEN TWO PROFILE,NO GOOD FOR MANUFACTURING.!!!! PLEASE EXPLAIN ONE PERSON.!!
Unread 24-04-2016, 11:00
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
Re: GT2 PROFILE 3-D CAD FILE FROM SDP/SI.
First off, please turn off the caps lock. Second, in general, you should not expect manufacturing drawings from any of the suppliers. You should be glad they include any teeth at all. For the most part, any CAD you download from a supplier will be a "customer" CAD file, meaning it will have the necessary geometry that recreates the interfaces. That includes files not only from SDP/SI, but FRC suppliers like AndyMark and Vex. In general, this is sufficient for designing things that use those components. They have to balance service provided to the customer versus protecting intellectual property. If you were provided with the manufacturing level CAD, then it would be trivial for anyone to take those and start manufacturing those parts themselves.
Unread 24-04-2016, 12:01
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight is an unknown quantity at this point
The actual tooth profile is not hard to work out. You can CAD a single tooth correctly and then create a pattern to make the remaining teeth. This also allows you to have any custom drive center that way. If 3d printing, having your own CAD allows you to adjust the drawing for the variations in the final printing geometry. (Ours shrinks a bit when cooled).
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 24-04-2016, 16:59
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
WE HAVE ORDERED PULLEYS FROM THEM BEFORE, AND WERE OK ON THE PROFILE! 192 ALSO USES THEIR PULLEYS WITHOUT ISSUES, PERHAPS YOU COULD CONTACT THEM.
SOMETIMES WHEN I OPEN CAD FILES FROM SDP-SI, THE TOOTH PROFILES LOOK MESSED UP OR PULLEYS ARE MISSING TEETH; IT'S NOTHING TO WORRY ABOUT.
<Now accepting CAD requests and commissions>
