Grip
Is it possible to use Grip without using Java because this year our team decided to use C++ or do we need to convert code into Java in order to use Grip.
Re: Grip
Re: Grip
Our team uses C++ and GRIP.
Re: Grip
Yes you can.
GRIP runs using Java, but it's output is through Network Tables. You can read those values from the Network Tables in C++. |
Re: Grip
GRIP is a separate application. It outputs values using NetworkTables. You will need to install Java on the roboRIO (or whatever device you are running GRIP on)
Re: Grip
You can definitely do it. Here's our vision tracking code.
