Go to Post We're moving to metric, inch by inch. - Joe Ross [more]
Unread 26-04-2016, 11:46
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
Rookie Year: 2013
samfruth will become famous soon enough
1710 Low Goal Scoring Autonomous Modes
Currently we have an auto to score in the low goal from all B and D defenses in the 2nd position and the Low Bar. Working on position 5 tonight.
Low Bar
Category B and D
I kind of know programming
Unread 26-04-2016, 21:31
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
Re: 1710 Low Goal Scoring Autonomous Modes
Woah! That last one over the rockwall did NOT look like it was going to line up. How did it correct itself? Are you using a gyro or does it just work like that. This is very impressive, by the way. Great work!
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
Unread 26-04-2016, 21:38
samfruth's Avatar
Team Role: Driver
Rookie Year: 2013
Yeah we couldn't believe it worked either to be honest! It was all done with the use of the navX sensor's gyro. That thing is awesome. Really easy to install and almost as easy to program with. We used it to cross all of those. Highly recommend it!
Unread 27-04-2016, 07:42
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
Rookie Year: 2010
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Looks really great!
1108 will be cheering for you.
You know you're carrying the flag for all of Kansas.
Unread 27-04-2016, 08:01
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Good work,
Some suggestions,
1. Work on position five, as many team will have low bar autons, and position two may interfere with what they do.
2. Try to mock up end wall and goal, as you are assuming you can just drop ball off and hit it.
3. look at the lakers 5053 auto goals, you will see that they cheat the angle to actually hit the wall, and use it to align the shot into the goal at the end. This will make the path to the goal more forgiving.
Even the low goal is tight.
The sooner we get behind schedule, the more time we have to catch up.
Unread 27-04-2016, 08:28
hrench's Avatar
AKA: Bob Hrenchir
Rookie Year: 2010
Originally Posted by tr6scott View Post
Good work,
Some suggestions,
While we're making suggestions, and I like tr6scotts, esp #1, everyone will want the low-bar, here's a couple from me:
1. If you're not going to try a 2-ball, I think the next logical thing would be to try to save as much Time as possible. So which defenses take the most time? Class A and C.
If looks to me like you could manipulate a CDF and still keep your ball. I don't know how you do the Porticullis, but again, since these are 'slow' defenses, you might as well try to get them while the 15 second clock is running instead of during the frenzy that is teleop.
And most robots can't do them from the front at all, but if anyone can open the sallyport or the drawbridge from the neutral zone, it would be very helpful timewise to plan to do that in the auto.
2. No matter what your robot does during auto shooting wise, driving back to the neutral zone is a real time saver. Even if you're afraid you can't line-up, at the very least you could back up and head that way. Does not take difficult programming to turn the robot back and drive in that direction. Doesn't help at all to end up sitting on the batter. Save time.
But alas, this is mostly too little and too late. Champs is here.
