Go to Post We are all just pawns in FIRST's quest for global domination. - Tom Bottiglieri [more]
Unread 04-28-2016, 04:38 PM
FlamingSpork FlamingSpork is offline
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
FlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really nice
Blue Alliance API OPR
Does the Blue Alliance API provide teams' OPR values, or will I need to calculate them myself?
Thanks!
Unread 04-28-2016, 04:39 PM
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Blue Alliance API OPR
It appears to be provided. See event stats.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
It's all there for you!
Take a look at the "Event Stats Request" section of http://www.thebluealliance.com/apidocs
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 04-28-2016, 04:50 PM
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
It appears to be a little funky on Archimedes at least. Earlier it was listing my team's OPR as 115.something.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 04-28-2016, 04:59 PM
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
You generally need to play at least 6 matches before OPR has any meaning. Before then it is a garbage value.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 04-28-2016, 05:10 PM
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
Thanks! I should have looked harder.
Unread 04-28-2016, 05:27 PM
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Not a bad rule of thumb, but it depends on the size of the event. With larger events, each team needs to play more matches before getting the same level of accuracy.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 04-28-2016, 05:45 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
http://www.chiefdelphi.com/forums/sh...3&postcount=21
Unread 04-28-2016, 10:07 PM
foote stepped in
AKA: E. Foote
FRC #0868
Originally Posted by Ether View Post
On each of those pretty graphs, where would you estimate the point OPR stabilized? I'd eyeball around 5-6 matches per team, although some sort bound on the delta opr / match might give a more accurate answer. Maybe it is stable once all OPRs don't change more than 2-5% after a match?
Unread 04-28-2016, 10:21 PM
Ether's Avatar
Rookie Year: 1969
Since each match generates 2 OPR equations (one for red alliance and one for blue alliance), you need at least T/2 matches to be played (where T is the number of teams) to get an overdetermined system of equations. As you can see from the graphs, it takes a bit more than T/2 to settle down.
But... did you look at the rest of that thread? Eugene Fang came up with a clever idea for getting around this limitation so that a stable OPR can be introduced right at the start of the event... and as matches are played the new data is used to refine the OPR. That new algorithm is used for the match predictions at the TBA site.
