Go to Post There are no easy answers... only complicated and never ending questions. - Shawn60 [more]
View Poll Results: What did you use for vision tracking?
Grip on RoboRio - IP Camera 3 2.07%
Grip on RoboRio - USB Camera 9 6.21%
Grip on Laptop- IP Camera 19 13.10%
Grip on Laptop- USB Camera 6 4.14%
Grip on Raspberry Pi- IP Camera 5 3.45%
Grip on Raspberry Pi- USB Camera 13 8.97%
RoboRealm IP Camera 6 4.14%
RoboRealm USB Camera 7 4.83%
Other - Please Elaborate with a Response 77 53.10%
Voters: 145. You may not vote on this poll
Unread 01-05-2016, 13:04
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
What Did you use for Vision Tracking?
This year my team didn't have time to get into vision tracking. I've been trying to dive into it but before I get started I was wondering what the best option was. I've heard a lot of speculation about what is good and what is bad. I was wondering what people actually used at competition. I would love to hear feed back on what worked and what didn't work.
Unread 01-05-2016, 13:14
BrianAtlanta's Avatar
BrianAtlanta BrianAtlanta is offline
FRC #1261
Rookie Year: 2012
BrianAtlanta has a spectacular aura aboutBrianAtlanta has a spectacular aura about
Re: What Did you use for Vision Tracking?
1261 used raspberry pi, with opencv. The vision code was written in python and used pyNetworkTables to communicate
Unread 01-05-2016, 13:54
Thanks for the in-site. How hard was it to write the code in opencv and use pyNetworkTables? Do you have any good resources or documentation that might help? Also how bad was the lag?
Unread 01-05-2016, 14:08
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
Rookie Year: 2013
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
We used a very similar setup, except written in c++. We actually had virtually no lag on the raspberry pi side. The only portion where there was lag was actually the roborio processing the data from the network tables.
The setup was pretty simple to get up and running. We compiled opencv and networktables 3 on the pi, then wrote a simple c++ program to find and send the necessary data to align with the target back to roborio. I actually followed a video tutorial here to install cv on the raspberry pi. For network tables, I downloaded the code off of github and simply compiled it like a normal program and added it to my library path if i remember correctly.
Unread 01-05-2016, 14:14
granjef3's Avatar
granjef3 granjef3 is offline
Code Ninja
AKA: Matt
FRC #2383 (Ninjineers)
Rookie Year: 2016
granjef3 is an unknown quantity at this point
2383 used a Jetson TX1, with a kinect used as an IR camera. Vision code was written in OpenCV using C++ and communicated with the roboRIO over network tables.
During the offseason we will be exploring the android phone method that 254 used for reliability reasons; the Jetson+Kinect combo was expensive and finicky, compared to an android phone with an integrated battery.
2016 Galileo Division Semifinalists with 341 Miss Daisy, 3683 Team Dave, and 4525 Renaissance Robotics
Thanks to all of our past alliance members!
Unread 01-05-2016, 14:31
ajacob ajacob is offline
Lead Programmer
FRC #2791 (Shaker Robotics)
Rookie Year: 2013
ajacob is an unknown quantity at this point
This year shaker robotics used the RRio with NIvision(java) to track the targets, we analyzed frames only when we needed them to prevent using too much of the rio's resources.
Unread 01-05-2016, 16:34
FRC #1261
Rookie Year: 2012
The code wasn't that hard for our developers, for openCV or pyNetworkTables. They looked at tutorials at pyImageSearch, it's a great resource. I think we were getting in the 20-30fps, but I would have to review our driver station videos. We would process on the Pi, calculate a few things such as, (x,y), area, height, (x,y) of center of image and such. This information would be sent via pyNetworkTables to the robot code. The robot code would use this information as input to elevation PID and Drivetrain PID.
The images were also sent via mjpg-streamer to the driverstation for drivers to see, but it's not really needed. We just liked seeing the shooter camera.
We'd be happy to help, just PM me.
Brian
Unread 01-05-2016, 14:56
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
1771 originally used the Axis M1011 camera, and GRIP on the driver station. However we had a problem on the field, the network table data was not being sent back, and we couldn't figure it out.
We switched to using a PixyCam, and had much better results.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 01-05-2016, 15:02
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
4901 used Grip on an a RPi v2 + a Pi Camera.
For more info on our implementation visit here https://github.com/GarnetSquardon490...ion-processing
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
"Head Bot Coach" FRC Team 4901 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1102, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 01-05-2016, 15:06
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
We used Java and OpenCV on an NVIDIA Jetson TK1, processing images from a Microsoft Lifecam HD3000.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 01-05-2016, 15:26
David Lame David Lame is offline
FRC #0247
David Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the rough
Like most engineering decisions, there isn't a "good" and "bad", but there is often a tradeoff.
We used GRIP on a laptop with an axis camera? Why? Because our code for vision was 100% student built, and the student had never done computer vision before. GRIP on the laptop was the easiest to get going, and it only worked with an i.p. camera.
There are down sides to that. If you use opencv, you can write much more flexible code that can do more sophisticated processing, but it's harder to get going. On the other hand, by doing things the way we did, we had some latency and frame rate issues. We couldn't go beyond basic capture of the target, and we had to be cautious about the way we drove when under camera control.
Coprocessors, such as a Raspberry PI, TK1, or TX1, (I was sufficiently impressed with the NVIDIA products that I bought some of the company's stock), will allow you a lot more flexibility, but you have to learn to crawl before you can walk. Those products are harder to set up and have integration issues. It's nothing dramatic, but when you have to learn the computer vision algorithms, and the networking, and how to power up a coprocessor, and do it all at the same time, it gets difficult.
If you are trying to prepare for next year, or dare I say it for a career that involves computer vision, I would recommend grip on the laptop as a starting point, because you can experiment with it and see what happens without even hooking to the robot. After you have that down, port it to a PI or an NVIDIA product. The PI probably has the most documentation and example work, so that's probably a good choice, not to mention that the whole setup, including camera, is less than 100 bucks.
Once you get that going, the sky's the limit.
Unread 01-05-2016, 16:24
That is very true and I got grip working on a laptop so I'm trying to figure out where the next best place to go is. I don't know much about vision processing algorithms, python or openCV.
There is a good documentation for the raspberry pi which I have been working on when I can.
Thanks for the reply
Unread 02-05-2016, 14:06
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
Rookie Year: 2007
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Team 230 also used a PixyCam... with awesome results and we integrated it in one day. The PixyCam does the image processing on-board so there is no need to transfer images. You can quickly train it to search for a specific color that you train it for and report when it sees it. We selected the simplest interface option provided by the Pixy which involves a single digital (indicating "I see a target") and a single analog (which provides feedback for where within the frame the target is located). This allowed us to provide a driver interface (and also program the code in autonomous) to use the digital to tell us when the target is in view and then allow the analog value to drive the robot rotation to center the goal.
The only issue we came up against after the initial integration was at Champs when the much more polished surface of the driver's station wall reflected back the LEDs to the camera simulating a goal target and we shot at ourselves in autonomous. It was quickly fixed by adding the requirement that we had to rotate at least 45 degrees before we started looking for a target.
The PixyCam is an excellent way to provide auto-targeting without significant impact to the code on the roboRIO or requiring sophisticated integration of additional software.
Unread 02-05-2016, 14:40
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
OpenCV C/C++ mixed source running on a Pine64 coprocessor with a Kinect as a camera. 30fps tracking using the Infrared stream. Targets are found and reduced to a bounding box ready to be sent over the network. Each vision target takes 32 bytes of data and is used for auto alignment and sent to the Driver Station WebUI for driver feedback. Code will be available in a few days, I'm boarding the plane home soon.
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
  #15   Spotlight this post!
Unread 02-05-2016, 15:15
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Team Role: Coach
Rookie Year: 2007
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
Nothing too fancy.
LabVIEW FRC Color Processing Example (Thanks NI. This was our most sophisticated use of vision ever, and the examples you provided every team in LabVIEW were immensely helpful.)
Running in a custom dashboard on the driver's station (i5 laptop several years old.)
Hue, Sat Val parameters stored in a CSV file with the ability to save new values during a match.
Target coordinates sent back to robot through Network Tables.
Axis Camera m1013 with exposure setting turned to 0 in LabVIEW.
Green LED ring with a significant amount of black electrical tape blocking out some of the lights.
PS. For Teleop we had a piece of tape on the computer screen so drivers could confirm the auto aim worked. If center of tape = center of goal, then fire.
PSS. Pop-up USB camera was not running vision tracking.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
