Go to Post Time to iterate, more. - jwfoss [more]
Unread 02-05-2016, 20:58
shui054 shui054 is offline
AKA: Sam Hui
FRC #1257 (Parallel Universe)
Rookie Year: 2014
shui054 is an unknown quantity at this point
Beginners Programming in C++
My team (FRC 1257) uses C++ to program the robot and I'd like to learn it. I've never really written code in anything except basic Python. Are there any good resources you know of to learning C++? Or how did you guys learn?
Any assistance would be amazing!
Unread 02-05-2016, 21:22
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Beginners Programming in C++
I've heard good things about Code Academy. Personally, I learned at a summer camp and subsequently took the C++ Intro class in college. You could look into a local community college and see if they offer a summer course or something.
As well, the WPI Library is a good place to start once you have a good handle on the basics of coding and want to know more about FRC specific applications.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 02-05-2016, 22:26
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
https://www.edx.org/course/introduct...soft-dev210x-1
Unread 02-05-2016, 22:58
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
learncpp.com has super comprehensive tutorials. Heavy on the text, but if you bear with it you'll learn a lot.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 03-05-2016, 00:23
jmullins16's Avatar
jmullins16 jmullins16 is offline
AKA: Jeff Mullins
FRC #2135 (Presentation Invasion)
Rookie Year: 2011
jmullins16 is an unknown quantity at this point
As a new C++ programmer, I encourage you to look at RobotBuilder and the Command-based robot template provided in the FRC tools. RobotBuilder is a graphical interface that will provide a set of C++ template files that are easy to work in. Even with only basic C++ skills, you can get a drivetrain defined and implemented very quickly. It will let you focus on how to make your robot work using C++ since it sets up all the files and syntax for an organized project.
Unread 03-08-2016, 17:40
Mitchell C Mitchell C is offline
FRC #0313
Mitchell C is an unknown quantity at this point
I've been working on a C++ guide on my team website http://www.bioniczebras.net/c++_guide.shtml
its not completely done but the only thing im still working on is the fancier auton verson. It uses Iterative as opposed to command based like most.
Unread 03-08-2016, 18:27
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
I've found the most important part of learning C++ to be understanding how memory management works (that might just be because I came from a Java background though )
Once you have a somewhat firm grasp on C++, I highly recommend writing a basic robot program from scratch. Run it on a test bot if your team has one, or use the WPILib simulator.
Or you could always switch to RobotPy
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
