Go to Post The ideals that are held by myself and by many of the longtime FRC mentors and volunteers whom I consider friends and colleagues are bigger than FIRST, and we will find (or make) another vehicle for them if we are forced to. - Jared Russell [more]
Unread 04-05-2016, 16:45
rlounds's Avatar
rlounds rlounds is offline
Registered Usr
AKA: Ryan Lounds
FRC #0865 (Warp7)
Team Role: Operator
Rookie Year: 2015
rlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to behold
Question Mecanum Java Code
Hi, so on my teams demo robot we're using mecanum wheels, a 4 slot cRIO and some victor 884s and we cant seem to get it working right. I don't know that much about code so it'd be great if I could get some help.
The code can be found below, any suggestions/correction are very much appreciated.
Code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Victor;
public class RobotTemplate extends SimpleRobot {
    RobotDrive myDrive;
    Joystick driveStick;
    public void robotInit() {
        driveStick = new Joystick(1);
        Victor frontLeft = new Victor(1);
        Victor frontRight = new Victor(2);
        Victor rearLeft = new Victor(3);
        Victor rearRight = new Victor(4);
        myDrive = new RobotDrive(frontLeft, rearLeft, frontRight, rearRight);
        System.out.println("Sample Text");
    public void autonomous() {
    public void operatorControl() {
        while (isOperatorControl() && isEnabled()) {
            myDrive.mecanumDrive_Cartesian(driveStick.getX(), driveStick.getY(), driveStick.getTwist(), 0);
            Timer.delay(0.01);
    public void test() {
Unread 04-05-2016, 17:01
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: Mecanum Java Code
What problems are you having with it? Are you getting errors? Does the robot move at all?
Quickly looking it over I don't see any problems.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 04-05-2016, 18:16
rlounds's Avatar
Registered Usr
AKA: Ryan Lounds
FRC #0865 (Warp7)
Team Role: Operator
Rookie Year: 2015
3 of our wheels don't go in the same direction and one doesn't move unless told to turn on the spot. Tried swapping some PWMs and that didn't help. I'm also not getting any errors with the code either...
Unread 04-05-2016, 18:48
Dartmouth 2020
AKA: lopsided98
Rookie Year: 2011
First, I would make sure you have the PWMs mapped correctly. If you are sure these are correct, it will make debugging everything else much easier.
Also, if you haven't already, put the robot on blocks so you can see what the motors are doing without having it try to drive around.
My guess is that you need to invert some of the motors. You can do this either in code (using myDrive.setInvertedMotor()), or by reversing the polarity of the wires that go from the Victor to the motor. When you push the joystick forward, all the wheels should move. If they don't you either have a problem with your joystick axes (what joystick are you using?) or your motor controller. Once all 4 wheels are moving when you command the robot to go forward, invert all the ones that are going backwards.
Unread 04-05-2016, 20:07
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
^^^THIS
Put the bot on blocks. In software, give the following commands, and for each, record what each of the wheels is doing:
Pure Forward
Pure Strafe Right
Pure Rotate clockwise
... then post your results. From those results, it will be possible to identify what needs to be changed.
Unread 04-05-2016, 20:14
rlounds's Avatar
Registered Usr
AKA: Ryan Lounds
FRC #0865 (Warp7)
Team Role: Operator
Rookie Year: 2015
When I'm back in our robotics space tomorrow I'll get the information about the wheels, and we're currently running the robot on top of a tote bin.
Head of Public Relations & Operator for FRC Team 865, Warp7
2016 GTR-C Quarter-Finalist (1310, 1325, 865)
2016 North Bay Regional Quarter-Finalist (2185, 4716, 865)
2016 Waterloo Regional Quarter-Finalist (2702, 5631, 865)
Unread 05-05-2016, 18:16
rlounds's Avatar
Registered Usr
AKA: Ryan Lounds
FRC #0865 (Warp7)
Team Role: Operator
Rookie Year: 2015
So after trying some stuff out, here's the list of things you asked for Ether. We're also using a Logitech Extreme 3D Pro for our joystick.
Pure Forward:
Front Right = Spins forward
Front Left = Not working at all
Back Right = Spins forward
Back Left = Spins forward
Strafe Right:
Front Right = Spins forwards
Back Right = Spins backwards
Back Left = Spins forwards
Rotating clockwise:
Back Right = Spins forwards
Back Left = Spins backwards
***NOTE: FRONT LEFT TURNS FORWARDS WHEN TURNING COUNTER-CLOCKWISE
Last edited by rlounds : 05-05-2016 at 18:22. Reason: Adding in the make of the joystick
Unread 06-05-2016, 13:50
Ether's Avatar
Rookie Year: 1969
Originally Posted by Ether View Post
Put the bot on blocks. In software, give the following commands...
Originally Posted by rlounds View Post
here's the list of things you asked for Ether. We're also using a Logitech Extreme 3D Pro for our joystick...
It sounds like you issued the commands by moving the joystick (hardware) instead of commanding them directly in software. Or am I misreading your post?
Pure Forward:
Strafe Right:
Rotating clockwise:
There is obviously something very wrong here. I suggest you try to get to the bottom of this first:
Try swapping Front Right and Front Left PWM cables and re-run the test. See if the problem follows the cables.
Unread 12-05-2016, 18:35
rlounds's Avatar
Registered Usr
AKA: Ryan Lounds
FRC #0865 (Warp7)
Team Role: Operator
Rookie Year: 2015
After all of the help I've received through this thread, we've manged to get everything working correctly. Thank you guys so much.
Unread 12-05-2016, 18:41
Ether's Avatar
Rookie Year: 1969
Please tell us why Front Left was not working at all.
Unread 12-05-2016, 18:43
rlounds's Avatar
Registered Usr
AKA: Ryan Lounds
FRC #0865 (Warp7)
Team Role: Operator
Rookie Year: 2015
The motor controller wasn't working correctly. We replaced it with another Victor 884 and it worked just fine. We also had a little incident of it another 884 sparking out and dying today so we'll also be changing it to use Talon SRs shortly.
