1.1 CFM Air Compressors?
What air compressor did your team use this year? Given the increase in the allowable air compressor CFM rating to 1.1, I am wondering what new legal compressors teams have found.
Re: 1.1 CFM Air Compressors?
We used a Thomas 215 this year. It run below the 1.1 CFM limit, but the rate at high pressures made it a great compressor to use this year. It does run hot, however. A fan on the piston housing cooled it nicely.
http://www.gd-thomas.com/templates/p...t.aspx?id=2722 |
We also use the Thomas 215. It's worked nicely for us for three years.
We used a viair 98C. However there website is now listing a higher CFM because they are using 13.8V instead of 12V this wasn't the case during build season. The ones we own list a 1.10 CFM at 12V directly on the compressor. I may need to call Viair and see if we can get 12V specs for their compressors published again.
Where are you purchasing the 215 compressor? The only place I've seen is here: http://cfpwarehouse.com/shopsite_sc/...oduct2931.html
But it looks super sketchy. Do you contact Thomas directly? |
The VLAIR 330C-IG is rated to 1.06 CFM at 12V and is 100% duty cycle, so no more overheating if it runs constantly...
The downside of course is that it also weighs over 8lbs. Would be handy if you needed a lot of air pressure and had spare weight to play with I guess. ![]() Last edited by cbale2000 : 08-05-2016 at 18:59. |
I'm not clear on why everyone is so big on the Thomas 215. Unless the viair 98C and 100C suffer significant performance hits for running at 12V instead of 13.8V, it seems like they have better flow rates and fill rates than the 215. |
We ran an off-board set up this year and loved it, I don't think we'll go back to on-board any time soon. However, our old trusty Thomas compressors are getting old, and we are looking to upgrade. This looks like a great alternative. -Mike |
I am a bit skeptical of running no compressor on one of our teams robots. Especially with our pneumatapult on our bot this year. Also not that I have any experience with the compressor but, Amazon seemed to have some comparable prices for the 330C-IG. |
#10
We had 8 tanks, all roughly the size of the black Clippard tank. It took about 5 minutes to charge using an old Thomas compressor. -Mike |
#11
Could you post the link for that calculator? I've been looking for something like this.
#12
We've been using the compressor off-board since FIRST opened up the pnuematic air tank rules in 2011 to allow plastic air tanks, and haven't looked back. Last edited by BenB : 10-05-2016 at 08:46. |
#13
Edit: The only issue we had was when we mounted our fittings into the head, we over-torqued it and cracked the head. We had a high-strength epoxy we used around the fitting and didn't have any issues. Last edited by galewind : 10-05-2016 at 20:23. |
#14
