Go to Post something i thought was impossible just happened: Brandon's awesomeness level has grown exponentially! just when you think he's at his peak, he does something new and extremely cool for CD. - Winged Wonder [more]
Unread 10-05-2016, 08:45
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
Re: 1.1 CFM Air Compressors?
Originally Posted by Michael Hill View Post
Where are you purchasing the 215 compressor? The only place I've seen is here: http://cfpwarehouse.com/shopsite_sc/...oduct2931.html
But it looks super sketchy.
Do you contact Thomas directly?
I've bought from these guys for 3 years -- no issues and fast shipping.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 10-05-2016, 08:25
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is online now
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Originally Posted by AllenGregoryIV View Post
We used a viair 98C. However there website is now listing a higher CFM because they are using 13.8V instead of 12V this wasn't the case during build season. The ones we own list a 1.10 CFM at 12V directly on the compressor. I may need to call Viair and see if we can get 12V specs for their compressors published again.
I contacted Vair about their 1.1 CFM compressors, and the customer service rep I spoke with said that the specs they have listed online are incorrect. He was familiar with the FRC pneumatic rules, and confirmed that they are NOT in fact FRC legal.
I wonder how many teams ended up with illegal compressors because the spec sheet was wrong...
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 10-05-2016, 08:43
roboruler roboruler is offline
Rookie Year: 2010
roboruler is infamous around these partsroboruler is infamous around these parts
Well considering that spec sheets can be used to prove the legality of components to RI's. What spec sheet evidence is there that these are illegal?
Obviously if it would create an unfair advantage, it would be un-GP to use even if the fact sheet was wrong.
Unread 10-05-2016, 08:49
The spec sheets are updated now. Here are some snippets from my convo with the rep. Not trying to put any teams on blast for using something with misrepresented properties; there's no way they could have known.
Regarding the 97C and the new 1.1CFM restriction
Originally Posted by VAIR
Eric,
No problem at all. We've had a few people inquire about that and our new testing has changed the CFM to 1.52. We are just waiting for final confirmation so it can be changed on our site.
Thanks,
VIAIR
Follow up asking about the 100C
Hello Eric,
Unfortunately even the 100C is going to be out of spec once we list the new CFM data. The new CFM at 0psi for the 100C will be 1.27.
Hope that helps and let me know if there is anything else I can help you out with.
Thanks,
VIAIR
Asking about other legal compressors
Hello Eric,
Thanks for contacting VIAIR! The only compressor we have seen work for FRC is the 90/92C. They are available through Andy Mark or a number of our distributors. That would be the least expensive option for you since they will also give you free shipping.
Thanks,
VIAIR
Unread 10-05-2016, 09:26
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Team Role: Coach
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
All of these values are for a supply voltage of 13.8 volts. The 100c, as an example, is 1.27 CFM at 13.8 volts. If 12 volts is the supply voltage, is the CFM reduced at the same ratio? 1.27 CFM at 13.8v is 1.10 CFM at 12v thus making it legal?
Like Aquidneck Island Robotics on Facebook!
Unread 10-05-2016, 09:37
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Math does not make them legal. Only a spec sheet detailing the CFM makes it legal. The Thomas 215 and VIAIR 90/92 meet those requirements.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 10-05-2016, 09:48
Rick's Avatar
Ready to STRIKE!
AKA: Rick Blight
Team Role: Coach
Is VIAIR aware that we run these compressors at 12 volts? It would be nice to a spec sheet for 12 volts.
We'll see what the 2017 rules and Q&A have for rulings.
Unread 10-05-2016, 09:55
Might be worth reaching out to them. Their customer service was very responsive!
Unread 10-05-2016, 10:12
FWIW I just checked, and VAIR lists the performance data of the 90/92/95C at 13.8V as well.
Unread 10-05-2016, 18:33
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Yes this is definitely an issue. I'll try to call them tomorrow if I have time. Do we know for sure that it was just their measurements that changed or did they change anything about the compressor it self. It would make sense that they would want to rate their compressors at higher CFMs (for every application other than FRC). Currently we have no way to prove the legality of any VAIR compressor since we don't have a 12V CFM rating at 0psi for any of them. We can assume the 90/92/etc are legal since we are supplying a lower voltage but we don't actually know their CFMs at 12V either.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
