Re: What COTS parts would you like to see?
I second what Sperkowsky said about the metal versaplanetary adapter and gussets. If it was metal it could be a lot smaller.
I would also like to see the versaplanetary encoder housing be made out of the same metal as the gearboxes because we had two of the plastic ones create a failure where once the encoder cracked and failed the entire gearbox would fall to pieces in our robot. The bolts failed in double shear and we had three pieces of each bolt every time this happened on two different gearboxes. I will attach photos to show the failure. I think we already sent this to Vex but I will check on that. I think vibration was the cause of the failure and not overloading based on our applications. I also strongly agree with what Marshall said and will add a little on to that. If the AndyMark kit came with bumper instructions and sheet metal hardware for next year I feel like some of the teams with fewer resources in NC would actually arrive to competition with bumpers and I would not have to help them build the bumpers before inspection! It would be nice to have something sort of like an "add plywood, noodle, and cloth kit" and you have a robot ready for inspection. |
The COTs parts available through Vexpro, AndyMark, and McMaster made all of our design work very easy. I'm glad we have so many parts available now compared to years ago!
One part we end up making a lot of, and isn't easy to do if you are a low resource team with no mill/lathe, is spacer inserts for tubes. These let you do through-bolt connections that can be tightened without crushing the tube, so you actually have a strong bolted joint. For VexPro in particular, spacers like this that fit their Versaframe extrusion sizes could be very useful for some teams. ![]() |
In recent years, we usually end up 3D printing all of our anti-crush supports, or else making do with lots of little cut-to-length tube spacers. With the first option, we waste time redesigning and printing the custom support blocks every year; with the second option, we waste time fumbling with (and dropping, losing, and needing to cut replacements for) dozens of tiny round spacers during assembly and maintenance operations. Standard anti-crush supports that fit inside the VersaFrame extrusions, on the other hand, should be fairly cost-effective if injection-molded en masse! |
Cause some people are OCD enough to not buy some things because they want things to match.
Actually, we're CDO. The letters are alphabetized as they're supposed to be.
One more thing I thought of: A VP 1:1 stage. Yeah I know you can directly hook the gearbox up to achieve this, but I'm talking about something you can drop in to replace an existing stage. Sometimes you go from 2 reductions to 1 reduction, but you want to use the same mounting holes, and a 1:1 spacer stage would be good for this. Using an encoder stage for this gets pricey.
![]() Quote:
BTW, the single stage 1:1 is a great idea. We ran into the same issue needing to refab the mount in order to convert from 1:1 to 4: 1. The same thought occurred to me. Why wasnt there an internal extension to enable 1:1 in a single stage case. |
#10
Some offseason designs, and our limited in house capabilities leave us wishing for 1/2" hex stock with a pilot bore (aka Thunderhex minus the rounded corners).
#11
Can you provide an example where the rounded corners make thunderhex shaft inferrior to regular hex shaft? Also thunderhex bearings alone should be enough of a reason to use thunderhex over Regular hex.
#12
The problem was not strictly with the thunderhex shaft, but in that particular application, using regular hex shaft would have possibly not worn out the plastic hubs (or at least would have delayed the problem). |
#13
Basically a plastic version of this: http://www.competitionrobotparts.com...oller-end-cap/ with a 1.125" OD.
#15
