Go to Post No amount of sleep beforehand will make up or prepare you for the lack of sleep you will receive during build season. - Dan Petrovic [more]
Unread 11-05-2016, 18:52
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
What COTS parts would you like to see?
We're at a point of the year where new products are probably being developed by FRC suppliers, so let's give them some ideas of what would help you build a better robot faster.
I'd personally like to see more 3/8" hex power transmission parts (sprockets, belt pulleys, etc.). Vex offers a 3/8" hex miter gear, but no power transmission means other than gears. We really wanted to use them on a 3-direction intake system, but kept hitting roadblocks. We could have gone with a round bore solution, but we went another direction.
I think a lot of us would like 3mm and 5mm pitch GT2 belt hex sprockets, though I understand there are patent issues with that.
What would you like to see?
Unread 11-05-2016, 20:34
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Re: What COTS parts would you like to see?
Everything that is currently being sold but in different colors. I would be interested in seeing if it would relieve some of the parts being bought out.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
#GLITTERFORCEHYPE!
Play is for kids this is serious...
Unread 11-05-2016, 21:33
Billfred's Avatar
Billfred Billfred is offline
How would different colors fix anything? Unless you had to boost the pre-color production to meet a MOQ, that doesn't change the quantity available (and even then, it creates more SKUs for vendors to have to pore over).
Unread 11-05-2016, 21:52
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
A metal versaplanetary cim adaptor.
And
More beefy right angle gussets
Unread 11-05-2016, 21:58
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Stronger alloy options for gear stages.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 11-05-2016, 22:06
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
Rookie Year: 2014
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Hex hubs with less slop. Would a steel version help with this problem?
Unread 11-05-2016, 22:21
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
No, steel hubs would not help. This is all dependent on the broach itself. Your best bet is to shim the hub if you want a tighter fit or custom make your hex shaft. Apparently soda cans work really well for shims! Just ask Devin
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 11-05-2016, 22:32
ASD20's Avatar
AKA: Andrew
Rookie Year: 2014
I'll have to try that. Thanks for the advice.
Unread 11-05-2016, 22:39
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is offline
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
VersaHub (1.125" Bearing Pilot, 3/8" Thick, w/ Plate Sprocket Mount)
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Unread 11-05-2016, 23:02
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is online now
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
Team Role: Mechanical
Rookie Year: 2014
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Mostly spacers, standoffs, and more shaft selection.
Spacers
  • 1/4 Threaded spacer for 1/8" and 1/16" 1x1 and 2x1 Al tube
  • Delrin spacers for 3/8" hex and 1/2" and 3/8" round
Standoffs
  • Common standoffs availble through Vex/AM/WCP to save on McMaster orders
  • Round and hex variants
Shafts
  • Thunderhex-style 3/8" hex with bore and similar variants for 1/2" and 3/8" round
  • Some grinding on the thunderhex to improve fit with hex bearings
  • Perhaps some steel variants of the current thunderhex/bored round shaft
Also, a more robust option for VP encoders. As mentioned above, plastic would be nice, but the boards and wires themselves need some sort of reinforcement.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 11-05-2016, 23:08
ASD20's Avatar
AKA: Andrew
Rookie Year: 2014
Spacers
VexPro offers an assortment of delrin 3/8 and 1/2 inch hex spacers.
http://www.vexrobotics.com/vexpro/ha...rs-vexpro.html
Unread 11-05-2016, 23:31
roboruler roboruler is offline
Rookie Year: 2010
roboruler is infamous around these partsroboruler is infamous around these parts
7075-T6 is the best alloy for aluminium gears available.
Yes, perhaps small gears such as those gears up to maybe 24 tooth could have the option of being replaced with drop in 4140 gears.
Unread 11-05-2016, 23:37
Chak Chak is online now
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Every broken gear picture on CD has the teeth sheered off. I've never seen the body of a gear crack. So, the failure mode seems to be the teeth. Would 4140 steel gears with lightening holes be an option? How much more would it cost?
Unread 12-05-2016, 00:19
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
The attached gear was pocketed on each side .112, leaving a web thickness of .150.
  #15   Spotlight this post!
Unread 12-05-2016, 00:56
Rookie Year: 2010
That is a 7075-T6 gear isn't it?
Andymark sell a few gears with weight saving holes in, I think in the weight saving your not going to be able to reduce enough weight to make it equal to an un-weight saved Aluminium gear however it would still be great to do some experimentation
Team 254 did some really nice weight saving for the large VEXpro aluminium first stage gear in their CIM-over wheel gearbox, I'm not sure if they had any problems with any gears during the season.
We probably don't want to hi-jack the thread with a Aluminium gear vs steel gear debate
