Go to Post Wow. Just wow. Never did I think the mentor built robot debate would make it on to a tv show. - ASD20 [more]
Unread 12-05-2016, 13:29
gofmannir gofmannir is offline
AKA: Nir Gofman
FRC #2096 (RoboActive)
Rookie Year: 2015
gofmannir is an unknown quantity at this point
Some one can teach me Vision Processing with labview?
Hello everybody
Some one can teach me how to perform vision processing with NI Vision Assistant or anything like this?
Thanks,
Nir.
Unread 12-05-2016, 13:40
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
Team Role: Coach
Rookie Year: 2011
aeastet is an unknown quantity at this point
Re: Some one can teach me Vision Processing with labview?
The easiest way is to use the examples that ship with LabVIEW. The example for this years game worked with no modification. You set up the camera add the LabVIEW example code and you are off and running. If you look at the menu bar in LabVIEW and go to help find examples and look for vision. It is all there.
Unread 12-05-2016, 16:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Along with the example code, there is also a tutorial that tells you exactly how to integrate the vision example into your robot project.
It works without fuss.
