#16
Re: Selecting Autonomous with TI LaunchPad?
In one of the Launchpad example control panels I wired up an 8 position one. You can see it here to get an idea of how to do it: http://processors.wiki.ti.com/index....nalog_Wire.JPG The red and black wire on either end of the resistor chain are +3.3V and gnd, and the one in the middle is the signal out. |
#17
In response to using a TI LaunchPad-
It would be much simpler, at least in my opinion, to use a Raspberry Pi Zero, as it is so inexpensive and abundant. It can pretty easily pretend to be a joystick with as many buttons as you want, and will have a LOT more support from outside sources and forums due to its much larger user base than the TI LaunchPads. Interesting and somewhat related side note- if I remember right from my tinkering with the Pi, the Driver Station pitches a fit if you have a joystick with more than 32 buttons/ axes/ pov's combined, so keep that in mind when constructing your interface regardless of controller. You might have to double up on microcontrollers if you want anything incredibly complex. |
#18
However, it won't be on the robot and uses only micro-b type connectors, which are latching (not locking, however), so it can withstand some abuse, but if you think it'll be roughed around too much, then definitely pick the LaunchPad. |
#20
Here's the unit we used. http://www.robotshop.com/ca/en/rotar...module-v1.html We really like it. You plug it right into an analog input on the RoboRio and just read the input voltage. The resistor network (similar to ILAMtitan's second photo) is internal, and there's a nice blue LED for visual feedback too. Plus, it's cheap! Last edited by GreyingJay : 14-06-2016 at 12:41. |
#21
This is how 1065 has selected auto modes for years now. 1 or 2 multi position dial and a toggle switch if needed. This year for instance we used the dial to select what we where driving over and position and then used a 3 position switch to determine if we would shoot high, low or do nothing once we got to the batter.
