Motor sizing
Hi,
I have a question about what size motor I should get for a project I'm working on. The robot will be 18" diameter with two 4" treads lining the base. I need two motors, one for each tread. It doesnt have to go fast but when maxed out it will need to lift 100-150 lbs. If anyone could help me out I'd greatly appreciate it. Thanks, mreda |
Re: Motor sizing
By 18" inch diameter I'm guessing your building a circular robot??? What is it going to do, just curious. For your motors you should probably using CIMs just because you won't ruin them if you happen to stall them out. If you know how to make a good gearbox for what your doing though I would personally go with 775 Pro's.
Re: Motor sizing
2 CIMs should be fine if you keep the speed down. You'll need to gear them down to around 10fps max (6-8 would probably be safer).
Re: Motor sizing
the 775 pro will be able to handle 150lbs? And would I be able to purchase a gear box as well? I plan on 3D printing the tread gears because I have been having trouble finding them as well.
Re: Motor sizing
You'll need to use gears to reduce the speed of the CIM to a more reasonable level. The "free speed" of the CIM is 5310 rpm, which is probably far more than you want for this. Vexpro and Andymark sell gears made to mount onto a CIM shaft, and gears for hexagonal shafts; a few pairs of gears will get you the speed you need.
Re: Motor sizing
what would you say would be the end goal for rpm. I was recommended previously to get a motor that would have cost me 150$ each and then I was going to have to get a motor driver as well which would have been another 100$ on top of that. This would definitely help the cost project if this ends up working out.
And I really appreciate your help with this. I know what I want to do, just not how to do it haha. Last edited by mreda : 12-05-2016 at 23:30. |
Re: Motor sizing
Your rpm depends on your wheel size. A higher wheel size will require a lower rpm to go as fast as a smaller wheel with a higher rpm. A 2" diameter wheel at 500 rpm will go: 2 *pi inches/rotation * 500 rotations/minute * 1 minute/60 seconds = 52.4 inches/second, or 4.36 feet/second (fps). If you're not very familiar with this sort of thing, finding somebody who is experienced or simply using easier, slower motors (like the motor/controller combo you were looking at) may be a better option. Andymark and Vex also sell premade gearbox options so you don't need to make anything. |
Re: Motor sizing
Ahh so correct me if im wrong, but this $18 motor will work as long as I can reduce the speed of it through gearing, whether I purchase a gear box or build a system myself?
Re: Motor sizing
It is one of the cheapest gear boxes that can accept 2 CIMs, and the default options seems to be about the gear ratio you want. Check if this will work with someone who knows more about your project though. For a motor controller, you should probably get SPARKs (like one of the previous posts stated). They are the cheapest motor controllers you can get, and are even on sale right now . |
#10
Re: Motor sizing
Re: Motor sizing
I highly recommend you find somebody who's already worked with FRC or robots in your area to help you; this would be an expensive mistake to make. |
#12
Re: Motor sizing
+1
#13
Re: Motor sizing
In terms of being able to handle the load though, would 775 pros motor and gearbox and SPARK motor controller theoretically work? http://www.vexrobotics.com/217-4347.html http://www.vexrobotics.com/vexpro/mo...reduction.html http://www.revrobotics.com/product/spark/ thanks again guys Last edited by mreda : 13-05-2016 at 00:12. |
#14
Re: Motor sizing
![]() 775pros could work, but because of their smaller mass you may face heating issues if you run this thing for a long time. CIMs are much safer and only cost slightly more (and have more reliable stock). |
#15
Re: Motor sizing
So this instead?
http://www.andymark.com/Motor-p/am-0255.htm |
