Go to Post And while I am not that big on hero-worship, I am pretty darn proud to know Dave. However, this does not mean that I will stop picking on him - MissInformation [more]
Unread 13-05-2016, 13:01
Jayd009's Avatar
Jayd009 Jayd009 is offline
AKA: Jonathan
FRC #4468 (Fernbank LINKS)
Rookie Year: 2016
Jayd009 is on a distinguished road
Help with Eclipse
Hello,
I am trying to use GitHub for my team's FRC programming next year. I uploaded a copy of last year's code to the repository. However, after I import it from GitHub, I keep getting three errors.
I have the JDK setup correctly in Eclipse, and I have the FRC plugins installed correctly, but I don't understand why other computers can't use the file.
I'm using a Windows 10 64-bit laptop.
Thanks,
Jonathan Daniel
2016: District Event Winner @ Columbus District Qualifier (PCH)
2016: Engineering Inspiration Award @ Peachtree District State Championship
2016: Tesla Subdivision Playoffs Appearance @ FIRST Championship
Unread 13-05-2016, 14:14
sagrossm sagrossm is offline
AKA: Sam
FRC #5712 (Hemlock's Gray Matter)
Rookie Year: 2016
sagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to all
Re: Help with Eclipse
I haven't read through this very well but this might help you, it's a guide to using github and eclipse.
http://wiki.eclipse.org/EGit/User_Guide#GitHub_Tutorial
Unread 13-05-2016, 14:52
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The error messages point to "unbound classpath variable" problems. That doesn't sound like Git's fault.
I'm going to take a wild guess and say that there's something in the project definition that needs to be changed to account for the fact that it's residing in a different place on the new computer.
Unread 13-05-2016, 16:12
jweston's Avatar
jweston jweston is offline
FRC #1124 (The Überbots)
Rookie Year: 2015
jweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to behold
I've helped our team often with this error. The problem is the plugin hasn't set up the necessary environment variables to tell the project where WPILib jars are.
To fix:
1. Go into Eclipse > Preferences.
2. Go into Java >Build Path >Classpath Variables.
3. Click New.
4. Enter Name: wpilib.
5. Click File... and navigate to <user directory>/wpilib/java/current/lib/WPILib.jar
6. Click OK.
7. Repeat steps 3-6 for:
Name: networktables, <user directory>/wpilib/java/current/lib/NetworkTables.jar
Name: wpilib.sources, <user directory>/wpilib/java/current/lib/WPILib-sources.jar
Name: networktables.sources, <user directory>/wpilib/java/current/lib/NetworkTables-sources.jar
I'm assuming you've installed the WPILib Eclipse plugin. If you haven't, please do so by:
1. Go to menu item Help > Install New Software...
2. Click Add...
3. Enter http://first.wpi.edu/FRC/roborio/release/eclipse/ for Location and click OK.
4. Check the checkbox next to WPILib Robot Development and click Next at the bottom until you finish.
Unread 13-05-2016, 18:46
Peter Johnson Peter Johnson is offline
WPILib Developer
FRC #0294 (Beach Cities Robotics)
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
The easiest solution (after you have the plugins installed) is just to create a new (temporary) Java robot project. You only have to do this once (per computer) and you can delete the temporary project afterwards. Creating the project will prompt you for the team number and set up the necessary wpilib etc Java classpath variables.
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 13-05-2016, 20:44
Jayd009's Avatar
AKA: Jonathan
Rookie Year: 2016
To fix:
3. Click New.
6. Click OK.
2. Click Add...
That worked perfectly. I'm no longer having the error on any of the computers. Thank you for your help!
