Weird Gearbox Sound
We were at an outreach event this past Saturday and our robot started acting weird. Here is a video: https://drive.google.com/open?id=0By...3lnRkZwN0FFaXM
Just some notes:
I can give more details as needed. Thanks! Team 2855 |
Re: Weird Gearbox Sound
I bet it's a dead battery.
When it stuttered and the orange RSL light flashed (not the normal flash, flashing with the stuttering motors), that led me to think it's the battery. You should be able to check the driverstation logs if you don't have the robot right now. |
As for the gearbox sound, they were taken around 5 seconds apart, one side, then the other. The robot hadn't been driven for about 45 minutes prior to that clip. So the grease freezing could be the source of the sound, but only one side sounded like that. The gearbox is a Toughbox Mini. No plastic parts (other than the casing). We currently have the robot bagged for the MN State tournament, but we have a pep fest on Thursday where we will be able to drive it again. |
Was the robot driven on or near anything that could have damaged the gears, such as sand? Did the robot take a drop or any sort of impact? Could anything have happened when it wasn't in use for 45 minutes? It sounds a bit like something rattling inside of the box, maybe a piece of plastic broke off and fell inside the box somewhere?
39%, at what load?
As batteries age, they may appear to still be good (have a high voltage) but under high load they drop voltage very quickly. If you're using the CTRE Battery Beak, use the % or voltage at whatever the highest load is (18A?). That should give you a better idea of what it will actually run at during driving. |
If you'd like, I'd be happy to stop by after work sometime this week - I know you have very little time to get it fixed before States, only 6 hours of robot access outside of the bag!
My first guess is a dead battery, and we can look through your driver station logs pretty quickly without unbagging the robot to see if that was the case. My second guess would be some sort of mechanical interference or damage, something that would require the robot outside of the bag and running to figure out, eating up work time! Let me known in a PM if you want me to swing by after 5 one of these days, I'm available all week (except for Friday, when I'll see you guys at load-in!). Edit for those curious: the Minnesota State High School League State Tournament is held every may, a few weeks after champs, and is a bag and tag event, following the district bag and tag rules of 6 hours of robot access leading up to the event. This is done to keep the playing field level for the event, as someone last competing in week 1 would otherwise have significantly more time than someone competing at Champs would. It's not perfect, but the best we can do! Last edited by Jon Stratis : 16-05-2016 at 16:33. |
As someone who has seen more matches than most (close up, on the field) I would check your pulleys and belts. It sounds, and looks, more like the belts were slipping than a gearbox gear broke. While I don't think the cold would have had that much of an effect, with the intermittent driving, there could have been some issues with heating and cooling of parts unevenly.
#11
We have had the belts slipping a few times this season, and this wasn't that. That was what I checked for first when it started acting weird.
#12
So, we had a little parade through the school this morning where we ran the robot, and the robot seemed fine. The stuttered movement never happened, so we think that that was due to the low battery.
As for the gearbox, it still had the weird sound like there was sand or something in the gearbox. The other gearbox sounded similar this morning. It ran fine, but we don't know what the sound is from. |
#13
If you are still experiencing these sounds, I would definitely take the gearboxes off and double check the gears. It's highly unlikely that you have managed to sheer teeth off the steel gears in the TB Mini, but this is the year of the strange failures.
A couple of quick questions: Did you run the gearboxes in for about 30 minutes prior to greasing them? Have you done any maintenance on the gearboxes this season? -Running outside might have introduced a foreign contaminant into the gearbox, and it might be worth cleaning the gearboxes out and greasing them again after checking the teeth. Have you checked the tightness of the screws holding the CIM motors on? |
#15
It kind of looks to me like nothing more than a brown-out. The stuttering and flickery RSL are the normal symptoms of brownout, and a difference in gearbox sound (because you aren't giving the motors your normal 11-13 volts) is expected. If your battery read as 39% (3.9V?) then you were probably well below brownout levels.
The fact that no one else mentioned this has me worried that I missed something obvious though ![]() |
