Go to Post It's easy to get overwhelmed. Don't get overwhelmed, just keep working at things a little bit at a time. (Oh, and don't forget to have fun!) - DominickC [more]
Unread 18-05-2016, 15:41
HolyRedPenguin HolyRedPenguin is offline
FRC #4361
HolyRedPenguin is an unknown quantity at this point
How to bypass/replace the VRM
Our team is trying to restore one of our old robots with the new electronics, but we do not have a VRM. Are there any ways to bypass or replace this?
Unread 18-05-2016, 15:43
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Re: How to bypass/replace the VRM
You might have one of the old 12V to 5V buck converters from the old control system. If all you needed the VRM for was to power the radio, this should be fine.
Look at the 12V to 5V converter on this page: https://wpilib.screenstepslive.com/s...w#!prettyPhoto
If you don't have one lying around, there are similar ones on AndyMark and Amazon.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 18-05-2016, 15:49
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
If you are using the old D-link radio this is fine, but the new open mesh radio is 12v source.
You could use the old radio with no issues if just for practice.
If you wanted to use the new radio, you could buy a boost converter that will give you a constant 12volts once adjusted.
like this one. http://www.amazon.com/DROK-Converter.../dp/B00J03PBW0
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 19-05-2016, 02:26
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
As others have said, try to use the older regulators if you can.
If it's a cRIO era robot with a PDB, AND you're not planning on working it too hard then you can potentially use the regulated outputs on the bottom of the PDB. This should work absolutely fine until you start moving. However if you've got a lot of heavy current draw motors, then you can potentially brown-out and lose power to these outputs. Use at your own risk.
Anecdotally, for a reasonably geared tank drive with 2-4 CIMs, I haven't had a problem with this "hack".
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
