Re: Is Welding Worth It?
Our team has found that drilling the correct size hole is the real key to having rivets stay in and be secure. For 5/32", you should be using either a #20 or #21 drill bit. Refer to the handy table on this page - http://www.engineersedge.com/rivet_application.htm Last edited by Ryan Dognaux : 20-05-2016 at 10:59. |
192 students has been welding for 20 years. Most of our welders learn in the in the fall with some starting the year before. Only a few have welded for years. Early on it was .125 or thicker. About 8 years ago I showed some students how to check for penetration by breaking welds with a hammer.
With the increase skill due to their critiquing their own welds we now weld .062 and thicker. 192 also rivets and has found that 3/16 and 1/4 rivets work rather nice and have few problems. |
We've welded our robot for the past 2 years. When you design before you weld, it works out very well. We use aluminum TIG welds.
I would say yes, welding is very much worth it. |
We have a student who is extremely good at welding. So, we've been welding our chassis for a very long time. Personally, I'd recommend it if you have the resources and the skills. We had 0 issues with damage to our chassis going over any of the defenses thanks to robust welds. I don't know much about it, but it seems there's a lot of depth to the skill. I'd go for it if you can.
