Go to Post What is it about inefficient design and operation that either pushes the envelope or deserves to be awarded? - Madison [more]
Unread 19-05-2016, 17:06
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Optical Encoder Problems
Hi y'all,
It's way past build season, but our team's still working on our robot. A couple days ago, both of our optical encoders on our drivetrain have stopped working. We have already checked our wiring, and tried switching out the encoders for new ones, yet the problem persists.
Is there any way to fix this? Thanks!
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 19-05-2016, 17:11
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Re: Optical Encoder Problems
Originally Posted by Hitchhiker 42 View Post
Hi y'all,
Assuming quadrature encoders:
Do you have an oscilloscope?
Power up the encoders and look at the A/B channels and see if they produce square wave forms as the encoder shaft rotates.
If not, there's a problem.
If you don't have an oscilloscope, maybe a DMM with a frequency function?
It's a little less friendly but you could test 1 channel at a time like that.
You'd have to rotate the encoder shaft over and over to make this work and at a consistent velocity.
If you are handy with TTL/CMOS you could make a little board with a counter on it, hook it up to each channel with an LED on the highest order bit...that bit should blink.
Again this requires rotating the encoder shaft over and over at a fairly consistent velocity.
Do you have an encoder you know works?
Put that on one of the encoder inputs...be very careful not to mess up how you power that encoder...and see if you can see that input in your robot.
If that works and yet your other encoders do not...pretty good chance those not working encoders are shot.
Unread 19-05-2016, 17:15
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Since both stopped working, it might indicate that the power being source for them has gone bad.
Assuming they are powered off the roborio, is the 5v and ground rail shorted?
Unread 27-05-2016, 19:14
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Team Role: Leadership
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
The discs may be scratched or out of place if they won't read properly.
Unread 27-05-2016, 21:58
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Highly suggest checking this. All of our problems with erratic RoboRio behavior turned out to be shorted power rails.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 27-05-2016, 22:10
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
+2 This, look for shrapnel in the roborio.
Rail status is also reported on the driver station.
(Be thankful you are not playing in the semi finals for MSC right now, like when it happened to us... then be thankfull that the drive coach chews gum, and the lead electrical person has much sharper eyes than me, and you get to play in the finals.)
The sooner we get behind schedule, the more time we have to catch up.
Unread 27-05-2016, 22:35
frcguy's Avatar
Unregistered Unuser
Rookie Year: 2012
We discovered ours right in between qual matches on Curie field, so I definitely hear you! Luckily, we had the foresight to get an additional RoboRio, and our drive team worked through lunch to swap it out. One of the most tense moments of the season for me.
