GRIP Help
Here is the error that I keep on getting
I am running 1.4.0 on a Kangaroo (I would update but I think a Kangaroo is only 32 bit) Code:
ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV ERROR: V4L: setting property #16 is not supported May 21, 2016 4:53:46 AM java.util.logging.LogManager$RootLogger log CONFIG: Configuration done. May 21, 2016 4:53:46 AM java.util.logging.LogManager$RootLogger log CONFIG: GRIP Version: 1.4.0 platform: /Linux/arm/ May 21, 2016 4:53:52 AM edu.wpi.grip.core.Main start INFO: Loading file /home/lvuser/project.grip May 21, 2016 4:53:54 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:53:54 AM edu.wpi.grip.core.operations.composite.PublishVide oOperation lambda$new$0 INFO: Starting camera server May 21, 2016 4:53:55 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [PipelineRunner] Starting May 21, 2016 4:53:55 AM edu.wpi.grip.core.Main start INFO: SUCCESS! The project is running in headless mode! OpenCV Error: Assertion failed (ssize.area() > 0) in resize, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp, line 3208 May 21, 2016 4:53:55 AM edu.wpi.grip.core.Step runPerformIfPossible WARNING: The CV resize operation did not perform correctly. java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp:3208: error: (-215) ssize.area() > 0 in function resize at org.bytedeco.javacpp.opencv_imgproc.resize(Native Method) at edu.wpi.grip.generated.opencv_imgproc.Resize.perfo rm(Resize.java:61) at edu.wpi.grip.core.Operation.perform(Operation.java :92) at edu.wpi.grip.core.Step.runPerformIfPossible(Step.j ava:152) at edu.wpi.grip.core.PipelineRunner.runPipeline(Pipel ineRunner.java:184) at edu.wpi.grip.core.PipelineRunner.access$100(Pipeli neRunner.java:35) at edu.wpi.grip.core.PipelineRunner$1.runOneIteration (PipelineRunner.java:68) at com.google.common.util.concurrent.AbstractSchedule dService$ServiceDelegate$Task.run(AbstractSchedule dService.java:189) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(Future Task.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.access$301(ScheduledThreadPoolE xecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.run(ScheduledThreadPoolExecutor .java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) May 21, 2016 4:53:55 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: The CV resize operation did not perform correctly. java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp:3208: error: (-215) ssize.area() > 0 in function resize at org.bytedeco.javacpp.opencv_imgproc.resize(Native Method) at edu.wpi.grip.generated.opencv_imgproc.Resize.perfo rm(Resize.java:61) at edu.wpi.grip.core.Operation.perform(Operation.java :92) at edu.wpi.grip.core.Step.runPerformIfPossible(Step.j ava:152) at edu.wpi.grip.core.PipelineRunner.runPipeline(Pipel ineRunner.java:184) at edu.wpi.grip.core.PipelineRunner.access$100(Pipeli neRunner.java:35) at edu.wpi.grip.core.PipelineRunner$1.runOneIteration (PipelineRunner.java:68) at com.google.common.util.concurrent.AbstractSchedule dService$ServiceDelegate$Task.run(AbstractSchedule dService.java:189) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(Future Task.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.access$301(ScheduledThreadPoolE xecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.run(ScheduledThreadPoolExecutor .java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) May 21, 2016 4:53:55 AM edu.wpi.grip.core.Step runPerformIfPossible WARNING: The HSL Threshold operation did not perform correctly. java.lang.IllegalArgumentException: HSL Threshold needs a 3-channel input at edu.wpi.grip.core.operations.composite.HSLThreshol dOperation.perform(HSLThresholdOperation.java:68) at edu.wpi.grip.core.Step.runPerformIfPossible(Step.j ava:152) at edu.wpi.grip.core.PipelineRunner.runPipeline(Pipel ineRunner.java:184) at edu.wpi.grip.core.PipelineRunner.access$100(Pipeli neRunner.java:35) at edu.wpi.grip.core.PipelineRunner$1.runOneIteration (PipelineRunner.java:68) at com.google.common.util.concurrent.AbstractSchedule dService$ServiceDelegate$Task.run(AbstractSchedule dService.java:189) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(Future Task.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.access$301(ScheduledThreadPoolE xecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.run(ScheduledThreadPoolExecutor .java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) May 21, 2016 4:53:55 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: The HSL Threshold operation did not perform correctly. java.lang.IllegalArgumentException: HSL Threshold needs a 3-channel input at edu.wpi.grip.core.operations.composite.HSLThreshol dOperation.perform(HSLThresholdOperation.java:68) at edu.wpi.grip.core.Step.runPerformIfPossible(Step.j ava:152) at edu.wpi.grip.core.PipelineRunner.runPipeline(Pipel ineRunner.java:184) at edu.wpi.grip.core.PipelineRunner.access$100(Pipeli neRunner.java:35) at edu.wpi.grip.core.PipelineRunner$1.runOneIteration (PipelineRunner.java:68) at com.google.common.util.concurrent.AbstractSchedule dService$ServiceDelegate$Task.run(AbstractSchedule dService.java:189) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(Future Task.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.access$301(ScheduledThreadPoolE xecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.run(ScheduledThreadPoolExecutor .java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) VIDEOIO ERROR: V4L/V4L2: VIDIOC_S_CROP VIDEOIO ERROR: V4L: setting property #16 is not supported May 21, 2016 4:53:55 AM edu.wpi.grip.core.operations.network.networktables .NTManager lambda$new$0 INFO: NetworkTables: Dispatcher.cpp:392 client: CONNECTED to server 172.22.11.2 port 1735 May 21, 2016 4:53:56 AM edu.wpi.grip.core.Main onExceptionClearedEvent INFO: Exception Cleared Event May 21, 2016 4:53:56 AM edu.wpi.grip.core.Main onExceptionClearedEvent INFO: Exception Cleared Event OpenCV Error: Insufficient memory (Failed to allocate 921600 bytes) in OutOfMemoryError, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/core/src/alloc.cpp, line 52 OpenCV Error: Assertion failed (u != 0) in create, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/core/src/matrix.cpp, line 411 May 21, 2016 4:55:01 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:01 AM edu.wpi.grip.core.GRIPCoreModule onThreadException SEVERE: Uncaught Exception on thread Thread[Webcam 0 Service,5,main] java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/core/src/matrix.cpp:411: error: (-215) u != 0 in function create at org.bytedeco.javacpp.opencv_videoio.cvRetrieveFram e(Native Method) at org.bytedeco.javacv.OpenCVFrameGrabber.grab(OpenCV FrameGrabber.java:237) at edu.wpi.grip.core.sources.GrabberService.runOneGra b(GrabberService.java:69) at edu.wpi.grip.core.sources.GrabberService.run(Grabb erService.java:61) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:60) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) May 21, 2016 4:55:01 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:01 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: RUNNING java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/core/src/matrix.cpp:411: error: (-215) u != 0 in function create at org.bytedeco.javacpp.opencv_videoio.cvRetrieveFram e(Native Method) at org.bytedeco.javacv.OpenCVFrameGrabber.grab(OpenCV FrameGrabber.java:237) at edu.wpi.grip.core.sources.GrabberService.runOneGra b(GrabberService.java:69) at edu.wpi.grip.core.sources.GrabberService.run(Grabb erService.java:61) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:60) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) May 21, 2016 4:55:01 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L: setting property #16 is not supported May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting VIDEOIO ERROR: V4L: setting property #16 is not supported May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDEOIO ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV VIDEOIO ERROR: V4L: setting property #16 is not supported VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDIOC_STREAMON: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener starting INFO: [CameraSource] Starting Unable to stop the stream.: Bad file descriptor Unable to stop the stream.: Device or resource busy VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDIOC_QUERYCTRL: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Camera service crashed edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor May 21, 2016 4:55:02 AM edu.wpi.grip.core.util.service.LoggingListener failed SEVERE: [CameraSource] Failed from: STARTING edu.wpi.grip.core.sources.GrabberService$GrabberSe rviceException: [Webcam 0] Failed to start at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:51) at com.google.common.util.concurrent.AbstractExecutio nThreadService$1$2.run(AbstractExecutionThreadServ ice.java:54) at com.google.common.util.concurrent.Callables$3.run( Callables.java:100) at java.lang.Thread.run(Thread.java:745) Caused by: org.bytedeco.javacv.FrameGrabber$Exception: cvGrabFrame() Error: Could not grab frame. (Has start() been called?) at org.bytedeco.javacv.OpenCVFrameGrabber.start(OpenC VFrameGrabber.java:214) at edu.wpi.grip.core.sources.GrabberService.startUp(G rabberService.java:49) ... 3 more VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor VIDIOC_QUERYCTRL: Bad file descriptor [ERROR] Too much output to display. Discarding the rest. [\CODE] The "VIDIOC_QUERYCTRL: Bad file descriptor" is since i turned off the robot Code:
<grip:Pipeline>
<sources>
<grip:Camera>
<property name="deviceNumber" value="0"/>
</grip:Camera>
</sources>
<steps>
<grip:Step name="Publish Video">
<grip:Input step="0" socket="0"/>
<grip:Input step="0" socket="1">
<value>80.0</value>
</grip:Input>
</grip:Step>
<grip:Step name="Publish Number">
<grip:Input step="1" socket="0"/>
<grip:Input step="1" socket="1">
<value>frameRate</value>
</grip:Input>
<grip:Input step="1" socket="2">
<value>true</value>
</grip:Input>
</grip:Step>
<grip:Step name="CV resize">
<grip:Input step="2" socket="0"/>
<grip:Input step="2" socket="1"/>
<grip:Input step="2" socket="2">
<value>0.6</value>
</grip:Input>
<grip:Input step="2" socket="3">
<value>0.6</value>
</grip:Input>
<grip:Input step="2" socket="4">
<value>INTER_LINEAR</value>
</grip:Input>
<grip:Output step="2" socket="0" previewed="false"/>
</grip:Step>
<grip:Step name="HSL Threshold">
<grip:Input step="3" socket="0"/>
<grip:Input step="3" socket="1">
<value>
<double>53.41726618705036</double>
<double>100.0</double>
</value>
</grip:Input>
<grip:Input step="3" socket="2">
<value>
<double>38.98381294964029</double>
<double>222.36348122866895</double>
</value>
</grip:Input>
<grip:Input step="3" socket="3">
<value>
<double>105.48561151079136</double>
<double>215.83617747440272</double>
</value>
</grip:Input>
<grip:Output step="3" socket="0" previewed="false"/>
</grip:Step>
<grip:Step name="Find Contours">
<grip:Input step="4" socket="0"/>
<grip:Input step="4" socket="1">
<value>false</value>
</grip:Input>
<grip:Output step="4" socket="0" previewed="false"/>
</grip:Step>
<grip:Step name="Filter Contours">
<grip:Input step="5" socket="0"/>
<grip:Input step="5" socket="1">
<value>0.0</value>
</grip:Input>
<grip:Input step="5" socket="2">
<value>0.0</value>
</grip:Input>
<grip:Input step="5" socket="3">
<value>0.0</value>
</grip:Input>
<grip:Input step="5" socket="4">
<value>1000.0</value>
</grip:Input>
<grip:Input step="5" socket="5">
<value>0.0</value>
</grip:Input>
<grip:Input step="5" socket="6">
</grip:Input>
<grip:Input step="5" socket="7">
<value>
<int>0</int>
<int>100</int>
</value>
</grip:Input>
<grip:Output step="5" socket="0" previewed="true"/>
</grip:Step>
<grip:Step name="Publish ContoursReport">
<grip:Input step="6" socket="0"/>
<grip:Input step="6" socket="1">
<value>myContoursReport</value>
</grip:Input>
<grip:Input step="6" socket="2">
<value>true</value>
</grip:Input>
<grip:Input step="6" socket="3">
<value>true</value>
</grip:Input>
<grip:Input step="6" socket="4">
<value>true</value>
</grip:Input>
<grip:Input step="6" socket="5">
<value>true</value>
</grip:Input>
<grip:Input step="6" socket="6">
<value>true</value>
</grip:Input>
<grip:Input step="6" socket="7">
<value>true</value>
</grip:Input>
</grip:Step>
</steps>
<connections>
<grip:Connection>
</grip:Connection>
<grip:Connection>
</grip:Connection>
<grip:Connection>
<grip:Output source="0" socket="0" previewed="false"/>
</grip:Connection>
<grip:Connection>
</grip:Connection>
<grip:Connection>
<grip:Output source="0" socket="1" previewed="false"/>
</grip:Connection>
<grip:Connection>
</grip:Connection>
<grip:Connection>
</grip:Connection>
</connections>
<settings>
<teamNumber>0</teamNumber>
<publishAddress>roborio-0-frc.local</publishAddress>
<deployAddress>10.36.47.2</deployAddress>
<deployDir>/home/lvuser</deployDir>
<deployUser>lvuser</deployUser>
<deployJavaHome>/usr/local/frc/JRE/</deployJavaHome>
<deployJvmOptions>-Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError</deployJvmOptions>
</settings>
</grip:Pipeline>
Can someone help me debug Last edited by josephno1 : 21-05-2016 at 00:54. |
