Go to Post Chairman's Award is not about building the robot. Every team builds a robot. - Retired Starman [more]
Unread 25-05-2016, 21:22
Kellen Hill's Avatar
Kellen Hill Kellen Hill is offline
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
Re: Integrating Encoder Into Gearbox
Originally Posted by cbale2000 View Post
I like that encoder mount, looks like it would be really simple to take on and off for maintenance, not to mention light weight. Are there issues with the mount shaking while it runs, or does it all fit pretty snug?
Any chance you could post the CAD for it?
Mounts lasted through 4 competitions with zero issues. The set screws on the coupler retained the encoder/mount from sliding in or out. I designed the mount to have just a bit of spring against the CIMs to make sure it would have a tight fit.
CAD file: Link
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 25-05-2016, 23:29
DinerKid's Avatar
DinerKid DinerKid is offline
AKA: Zac
FRC #1768 (Nashoba Robotics)
DinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of light
Similar to the lexan Z mounts, we have seen success in the past with small aluminum mounts (these fit really nicely in the lightening holes of other parts that are cut on a water jet, which makes for efficient layouts). These can then be secured to the frame with a rubber mount which can be purchased from McMaster here.
As for the shaft of the encoder we simply drill the appropriate hole in the shaft (haven't always reamed the hole) and secure it with some loctite 680 (which has a diametrical clearance max of 0.015" so your hole doesn't need to be all that precise). Takes a heat gun to remove it, but luckily none of the defenses this year involved a heat gun, so the encoders stayed put.
We made this our standard method of mounting encoders and potentiometers in 2015. The rubber mounts allow for some give, allowing some misalignment, but are quite rigid which I would imagine eliminates the issues seen with latex tubing used as a coupler.
~DK
Name:	Screen Shot 2016-05-25 at 11.23.20 PM.png
