pic: FIRST FRC Participation
Re: pic: FIRST FRC Participation
Can anyone provide insight as to what happened in 2004/05? Did some grant project fund rookies then stop support?
How does the growth rate chart to attrition? It would be nice to see that chart with Growth as a percentage compared to Attrition as a percentage...
EDIT: nevermind, please delete this post
/edit: Yes, the registration fee was increased by $1000 for the 2005 season. http://www.chiefdelphi.com/forums/sh...on+2005 +fees Last edited by Karthik : 24-05-2016 at 14:22. Reason: New info |
Is the 2010-2011 bump in rookies due to the JCPenny grant? I can't remember when that began/ended. Know there were a ton of teams that took advantage of that.
Edit: That's when Districts began in Mich, right? $1000 bump in registration is pretty big. Were rookies always $1000 more than vets or when did that start? |
Thanks, Karthik.
I believe the differentiation between the "rookie kits" and "veteran kits" began in 2010 (the second year of the cRio). For most of the duration of the IFI controller, all teams got a new control system each season. |
#10
If my memory serves me correctly, the 2005 season was the first year of the modern era, but was not the first year of the modern frame perimeter. That structure has been evolving since 2000, the second year of alliance play. The increase in the registration fee also did not coincide with the move to the GWCC, but happened after the first year in the dome.
The remarkable team attrition might have been noticed by FIRST, as the FIRST VEX Challenge had its initial pilot a year later. Quote:
What was the first year teams used the IFI boards? Did the registration fee fall down to $5000 in 2010 to coincide with the 1-time control system transaction, or was the move done independently? I have only been covering registration since 2011. |
#11
The FIRST Vex Challenge actually had a pilot event in 2005, at the FRC Championship. The timing had more to do with the Vex kits becoming a full fledged product line in 2005/2006 (carried in Radio Shack, rather than the Edubot kits sold directly by IFI prior to that point).
#12
Yup, the fee change was based on the new policy of not supplying teams with a control system each year. |
#13
Not sure I'm reading the graph right. I see a the rookie line at 2%. So it makes sense if you add 2% to exisiting teams that existing teams goes up. But 1% die, so the existing teams should die by 1% So the overall growth should be 1%.
Granted, I'm looking at the chart, I'm confused by it. TLI5, how to read the graph. |
#15
