Go to Post Weren't you ever told Canada is backwards from the US? - Alex Cormier [more]
Unread 26-05-2016, 12:21
beckster1999's Avatar
beckster1999 beckster1999 is offline
Becky the robotic cat *prrrrr beep*
AKA: Becky
FRC #2877 (Ligerbots)
Team Role: Electrical
Rookie Year: 2013
beckster1999 is an unknown quantity at this point
swerve drive with arduino mega 2560
hi, thus isnt for my team, but in my engineering class at school im working on a swerve drive but, but i have no experience programming since i usually stay on electrical. could someone help me figure out the code?
Unread 26-05-2016, 12:44
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & SLFF (NE Way You Want It)
Rookie Year: 2011
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Re: swerve drive with arduino mega 2560
You will need encoders for each wheel's rotation, a motor to spin each wheel module, and a motor to drive each wheel. More info on swerve drive mechanics can be found here.
For the programming, check out this document published by Ether which will help you control how your swerve works.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 26-05-2016, 20:02
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
I tried running swerve calculations on an XMOS, which is approximately 20x as powerful as an Arduino Mega. I don't believe I threaded on it though, so it was only about 5x as powerful.
My advice: don't do it. Crab drive is very easy to get working, but if you want true swerve motions like snake/ocelot turns, it's going to be difficult due to the math involved in vector addition. The Arduino is not optimized for the trig functions you need to use, and it will slow you down a lot- and that's before even trying PID or even just P controls on module rotation.
I believe I got somewhere between 50-100ms per loop, from reading joystick to motor controller outputs. This was however fr from optimized, as I was using a custom PWM generator that ran once per loop to make the motor control signals. Using the Arduino Servo library to control would help reduce the main loop loading.
If you do try it, optimize for speed. Avoid full swerve motion (crab is cool enough anyway, and scrub shouldn't be a problem on a small scale). If you want to do full swerve, find a way to approximate the trig to add vectors so you don't bog down the processor.
<Now accepting CAD requests and commissions>
Unread 27-05-2016, 10:54
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Running a full swerve system on an Arduino is certainly possible, but it may be more of a challenge than you would like to take on. The biggest issue with the Arduino is that it does not have a floating point execution unit in the CPU. That means that all floating point operations have to be performed in software. Relatively speaking, this is very slow. In a typical swerve application, there are many FP operations required to determine steering angle, and wheel speed utilizing trig functions, PID loops, etc. If you attempted to do this directly on the Arduino, it would not have the processing power to perform these operations in a timely manner. A number of teams had swerve drives in the old IFI controller days. These controllers, while quicker than the Arduino - 40 MHz as opposed to 16 MHz for a Mega, also did not have a FP unit. Several strategies were used as work arounds to minimize or eliminate the need for floating point calculations including fixed point math and integer trig approximations. I would also recommend that you look into efficient interrupt driven routines for, what I will call, background tasks (encoders, analog signal A/D, PWM generation); again to minimize CPU usage and unnecessary delays.
For reference, I used an old IFI controller (2007 vintage - it was free) to make a swerve drive about a year ago using the techniques I mentioned above. It is a full swerve, with multiple modes including snake, and I am confident that I could make it work on an Arduino as well. However, I wouldn't recommend it unless you are willing to put a fair amount of time as it will not be easy (but a great learning experience!).
Mike
Unread 27-05-2016, 13:50
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
This robot is running full 4 wheel swerve on an Arduino...
https://youtu.be/hdAmpk0PQ3I
The controls code is based on the Ether paper. Ether also helped write some integer based routines to optimize the code...it works great.
More firepower would be great, but it isn't required.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 27-05-2016, 14:20
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
If you want trig functions you don't actually need full floating point support: use a look-up table.
http://www.societyofrobots.com/progr...rigtable.shtml
BTW there are trig look-ups masked into the Parallex Propeller just for this reason,
https://www.parallax.com/sites/defau...anual-v1.2.pdf
Page 34.
Unread 31-05-2016, 10:37
AKA: Becky
Rookie Year: 2013
all oof the answers are confusing me, the calculations i can probably figure out on my own, and the whole thing is completely set up except for the code, which is what i need help with. i put the issue in the description of the problem im having. butvtganks anywayb also, i cant switch the setup of what im using significantly, like using somethingbother than a swerve drive, arduino, ot talons, but i can out thungs on it. also, sorry for the spelling mistakes, im using a touch screen computer and its hard to type correctly
Unread 31-05-2016, 10:53
AKA: Becky
Rookie Year: 2013
i just realized I didn't put the issue in for lack of time, here is what is going wrong:
i clicked burn bootlegger after doing all previous steps correctly and this came up-
Arduino: 1.6.9 (Windows 8.1), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
becky the robotic gerbil (btw anyone wanna help me make on starting next school year? i need a team and many years which is why I am starting in high school)
Unread 31-05-2016, 11:11
AKA: Anthony Lapp
Rookie Year: 1996
I'm not sure why you would have to do "burn bootloader." Arduino boards come hot out of the gate ready to go.
Under "tools->board" make sure you have the correct Arduino hardware selected. Then check that you have the correct "com" port selected.
Then press the upload arrow and you should be running code. Test this with the supplied examples before trying to upload your own custom code.
Anthony Lapp
RobotOpen
Unread 31-05-2016, 11:38
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
+1. It looks to me like they may be saving their compiled code as a .hex file and flashing it to the Arduino. OP, you should try uploading code with the Arduino IDE.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 31-05-2016, 11:42
AKA: Anthony Lapp
Rookie Year: 1996
Agreed.
The whole point of an Arduino is to be "foolproof." Start with using their supplied tool and examples to make sure everything is working as expected...then try your custom config.
Anthony Lapp
RobotOpen
Unread 31-05-2016, 21:30
FRC #1126 (& 1511)
Hi Becky,
I just ran through an installation of the Arduino software (I needed to upgrade anyway) and downloaded to a Mega and will list the steps that I went through to get it to work (there may be other ways, this is just what I used). Most of this is just a repeat of what others have said above.
1) Open a new sketch and cut/paste the Blink code example that can be found here near the bottom of the page. This is just to have a known good sketch to test.
2) In the menu item Tools->Board select "Arduino/Genuino Mega or Mega 2560"
3) In the menu item Tools->Programmer select "AVR ISP"
4) Verify your code by clicking on the left hand button with a Check Mark in it just below the menu items (The word "Verify" should display to the right of the buttons when you hover your mouse over it). It should return some messages at the bottom if the IDE indicating how large the sketch is and global variable use.
5) Plug in your Mega if you haven't already done so.
6) In the menu item Tools->Port, select the your Mega. Mine was labeled "COM3 (Arduino/Genuino Mega or Mega 2560)". Yours may have a different COM number.
7) Upload to the Mega the Blink program by pressing the right arrow button next to the verify button you used earlier. To the right of the buttons it should show the word "Upload" when you hover over it with your mouse. After a few seconds a message indicating "Done uploading." should be shown below your sketch and above the message area it it worked correctly. Also, the led on the mega (yellow on mine) will be blinking at 1 second intervals.
This worked on mine. If this works for you, then you should be able to upload your own sketch, but you may have to change the Board, Programmer & Port again (Steps 2,3 & 6) after you open your sketch. If this doesn't work, if you can post any error messages you are seeing, that would help us identify the problem.
Mike
Last edited by Mike Bortfeldt : 31-05-2016 at 21:32. Reason: Corrected a couple of words
Unread 01-06-2016, 11:36
AKA: Becky
Rookie Year: 2013
it is working now, but I still don't know how to code more than in extremely basic python, so im not sure what to do. ill post a picture of the whole thing in a few minutes in case that is helpful. the code is empty as of right now.
Unread 01-06-2016, 11:39
AKA: Becky
Rookie Year: 2013
blob:https%3A//mail.google.com/6927b9bd-8c0e-4b71-91b0-fd0a0535bec7
here it is
  #15   Spotlight this post!
Unread 01-06-2016, 14:31
FRC #1126 (& 1511)
The URL doesn't seem to work for me. Can you try to post the picture or copy it to some other location?
Mike
