Go to Post Read the manual. Know the manual. Love the manual. - Koko Ed [more]
Unread 31-05-2016, 14:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Is Magnesium ok?
The caution against getting it wet might be confusing magnesium for sodium (or potassium or another alkali metal). While it does burn spectacularly as a powder or shavings (or when molten), there is a significant difference between alkali metals and alkaline earth metals. Sodium reacts with water and is likely to ignite the hydrogen produced by the chemical reaction. Magnesium only has issues with water when it's already burning.
Unread 31-05-2016, 20:44
DonRotolo's Avatar
Back to humble
FRC #0832
As many have noted, Magnesium in typical form is no more dangerous than any other metal - even underwater. However, smaller chips or particles are able to be ignited, and then become extremely difficult to extinguish.
Yes a class D extinguisher has a chance, but hav limited effectiveness and are costly.
If you use the metal and don't need to machine it, you'll be fine. But if it needs to be machined, you are better off avoiding it. The risk is small but the consequences very large.
Unread 01-06-2016, 00:38
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Originally Posted by Mike Schreiber View Post
Wasn't the housing on the NI cRIO magnesium? No one started any fires - although hopefully no one was machining it.
No, it was almost certainly certainly steel. Those things were heavy!
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
